(2020-11-05, 22:55)HugoL Wrote: [ -> ] (2020-11-05, 22:43)Aaiemron Wrote: [ -> ] (2020-11-05, 22:22)HugoL Wrote: [ -> ]Ok but what’s this got to do with your homescreen layout?
Try going to configure shortcuts and use both the restore options under Reset Menu to Defaults.
Then go to Back up and Restore and use the Reset the Skin to defaults option.
Report back after this and let me know what systems you’ve tried this on.
That's because I have to choose a layout first in the "normal" Bingie, to see a skin at all. I thought I had to do that in the Mod version also
Did you mention this a few months back? You're on Mac right? I know someone said they had to do this on Mac.
Yes, I am on a Mac. But it happens also on Android
(2020-11-05, 22:56)Aaiemron Wrote: [ -> ] (2020-11-05, 22:55)HugoL Wrote: [ -> ] (2020-11-05, 22:43)Aaiemron Wrote: [ -> ]That's because I have to choose a layout first in the "normal" Bingie, to see a skin at all. I thought I had to do that in the Mod version also
Definitely doesn't happen on Android. At least not on firestick 4K. So was this you that mentioned it previously? And did you do what I asked?
(2020-11-05, 22:58)HugoL Wrote: [ -> ] (2020-11-05, 22:56)Aaiemron Wrote: [ -> ] (2020-11-05, 22:55)HugoL Wrote: [ -> ]Did you mention this a few months back? You're on Mac right? I know someone said they had to do this on Mac.
No, that was another person.
What steppes can I take to make it work?
(2020-11-05, 23:00)Aaiemron Wrote: [ -> ] (2020-11-05, 22:58)HugoL Wrote: [ -> ] (2020-11-05, 22:56)Aaiemron Wrote: [ -> ]Yes, I am on a Mac. But it happens also on Android
Strange, they had the same problem in bingie 1.03 and the same solution. Black screen until they went to homescreen layout and then selected bingie layout. The strange thing is that is bingie 1.03 is already set to bingie layout by default so I have no idea how this work-around would even work.
What steps can you take? You can start with the ones I mentioned in my first reply to you. Also make sure you're using the latest version.
(2020-11-05, 22:51)Aaiemron Wrote: [ -> ] (2020-11-05, 22:48)AchillesPunks Wrote: [ -> ] (2020-11-05, 21:32)Aaiemron Wrote: [ -> ]Hello. When I install Titan Bing skin the I can choose the Homescreen Layout as you can see in the picture:
But with the Titan Bing Mod version there is no Homescreen Layout where I can choose from:
This happens both on Mac and Android. Am I doing something wrong?
It's been removed
What exactly?
The home layouts you asked about
It's been removed
Maybe you have to bring it back to make it work?
I have tried all other steps to make it work, but always a black screen. Maybe it's a Mac issue
(2020-11-05, 23:35)Aaiemron Wrote: [ -> ] (2020-11-05, 22:48)AchillesPunks Wrote: [ -> ] (2020-11-05, 21:32)Aaiemron Wrote: [ -> ]Hello. When I install Titan Bing skin the I can choose the Homescreen Layout as you can see in the picture:
It's been removed
But you said it happens to you on Android too. It's hard to help you when we're not getting the right info. Please confirm your android issue and please also confirm the steps you've taken.
(2020-11-05, 23:55)HugoL Wrote: [ -> ] (2020-11-05, 23:35)Aaiemron Wrote: [ -> ] (2020-11-05, 22:48)AchillesPunks Wrote: [ -> ]It's been removed
I just installed the update on my Android, and I'm having no issues
I just installed it again on Android an after a restart I got it working!
Installed the Titan Bingie first with all the addons and at last the Titan Bingie Mod. It worked after a restart.
Mac keeps failing. Only black screen
(2020-11-06, 00:15)Aaiemron Wrote: [ -> ] (2020-11-05, 23:55)HugoL Wrote: [ -> ] (2020-11-05, 23:35)Aaiemron Wrote: [ -> ]Maybe you have to bring it back to make it work?
OK Android solved. Now please can you confirm the steps you’ve taken on Mac?
(2020-11-05, 20:00)jokero009 Wrote: [ -> ]Dear developers of this mod .. I am infinitely grateful that thanks to you I can feel the whole atmosphere of Netflix!) And even better
But I really ask you to make a beautiful Russian font!) I like English and in no case want to say anything bad, but due to the inaccessibility in kodi, change the font to Russian all content and everything in English (Please add support for the Russian font for this skin-)
Added back the original font to hopefully support non-latin characters (at least the ones the original Bingie 1.03 supported).
Download again and switch to "original" font through the interface.
AchillesPunks may as well update the changelog.
(2020-11-05, 14:15)leo06 Wrote: [ -> ] (2020-11-05, 13:57)HugoL Wrote: [ -> ] (2020-11-05, 12:01)leo06 Wrote: [ -> ]I can’t choose different fonts. The Greek language is not supported, the info for movies and tv shows that is in Greek is shown like squares
Does the original font work for Greek language? I can bring that one back, just need to make a few adjustments first.
The default fonts from titan bingie are working
(2020-11-03, 15:55)minhgi Wrote: [ -> ] (2020-11-03, 12:13)HugoL Wrote: [ -> ] (2020-11-03, 05:38)haicaoboi87 Wrote: [ -> ]The fonts in bingie mod skin not support vietnamese character.
And the Addon you used is illegal and not supported by kodi communication
Yep, I could bring back the original font (if this was working for Vietnamese characters) but would need some work to make sure its now compatible with all the cosmetic changes we made first.
Would appreciate it.... I now noticed also switch the kodi language to viết. The interface throughout the skin affect kodi as a whole and not just that one specific addon. Didn't realize it was unicode issue.
Done! Download again and switch to "original" font through the interface.
Hey Hugo, might not be the right place to ask so if anyone tells me ill delete or stop asking here, im setting up library integration on a fresh build just in case i fuck stuff up and the watched statuses are syncing up, however i have a few questions. How much stuff do you have in your library cause I feel like my watchlist and current shows are not enough to fill up a library as big as netflix. I think im just gonna have to add a boat load of shows and movies that i dont even watch just to get it looking right u know what i mean.
My next question is how can i get widgets like Trending, Popular using my library? Like for example lets say i have hundred shows but the trending now widget from TMDB Helper has shows like Mandalorian, Queens Gambit, The Boys, Walking Dead, etc that i dont have in my library for whatever reason how can i get shows like that to show up? I guess I cant? and how can i even set up widgets like trending that would update with current times or whatever, without having to setup smart playlists and things like that; if i have to then ill look into it but im confused enough already with library integration haha
