Hey guys quick question I read about the last 10 pages of the thread didnt see the answer. How do you get the IMDB top 250 to work I went into my information providers and enabled IMDB and did a library scan but no dice what am I missing?
(2020-11-06, 20:09)cscott1 Wrote: [ -> ]Hey guys quick question I read about the last 10 pages of the thread didnt see the answer. How do you get the IMDB top 250 to work I went into my information providers and enabled IMDB and did a library scan but no dice what am I missing?
Are you talking about the new sub label one?
They should just work by default. Its been set so if doesn’t find the info in your database it will still get it from skin helper instead.
Check you have not disabled sub label on home spotlight (this ones just for the spotlight content though), found in the spotlight section of homescreen layout.
Or check you have not disabled Top250 sub label on home and bingie views found under Details Options of Homecreen Layout.
(2020-11-06, 20:28)HugoL Wrote: [ -> ] (2020-11-06, 20:09)cscott1 Wrote: [ -> ]Hey guys quick question I read about the last 10 pages of the thread didnt see the answer. How do you get the IMDB top 250 to work I went into my information providers and enabled IMDB and did a library scan but no dice what am I missing?
Thanks for the advice but both of those settings are enabled. You or anyone else have any other ideas?
(2020-11-06, 20:29)mathu204 Wrote: [ -> ]https://imgur.com/a/FDugKN8
here is the results but it never saves my changes @HugoL for resoltuion
Do you not have a 1920 x 1080p capable laptop?
Also, why is your monitor set to Generic PnP Monitor # 1?
(2020-11-06, 20:39)cscott1 Wrote: [ -> ] (2020-11-06, 20:28)HugoL Wrote: [ -> ] (2020-11-06, 20:09)cscott1 Wrote: [ -> ]Hey guys quick question I read about the last 10 pages of the thread didnt see the answer. How do you get the IMDB top 250 to work I went into my information providers and enabled IMDB and did a library scan but no dice what am I missing?
Are you getting Director on spotlight content sub label (only displays on films)?
(2020-11-06, 20:44)cscott1 Wrote: [ -> ] (2020-11-06, 20:41)HugoL Wrote: [ -> ] (2020-11-06, 20:39)cscott1 Wrote: [ -> ]Thanks for the advice but both of those settings are enabled. You or anyone else have any other ideas?
Yes
Ok.
And are you sure you’re focusing on titles that are in IMDB’s top 250?
(2020-11-06, 20:49)HugoL Wrote: [ -> ] (2020-11-06, 20:44)cscott1 Wrote: [ -> ] (2020-11-06, 20:41)HugoL Wrote: [ -> ]Are you getting Director on spotlight content sub label (only displays on films)?
Yes
Ok.
I'm an idiot sorry for wasting your time I was just scrolling and didn't see any went to shawshank and sure enough it's there. Thanks.
(2020-11-06, 20:53)cscott1 Wrote: [ -> ] (2020-11-06, 20:49)HugoL Wrote: [ -> ] (2020-11-06, 20:44)cscott1 Wrote: [ -> ]Yes
Ok.
No worries. You get top 250 for shows too.
Something must be up with your monitor driver. Pretty sure it shouldn't say "generic monitor". Check you have the right driver for your laptop monitor.
(2020-11-06, 20:40)HugoL Wrote: [ -> ] (2020-11-06, 20:29)mathu204 Wrote: [ -> ]https://imgur.com/a/FDugKN8
no i dont think this laptop can, also idk how to change the monitor setting i cant click it or go to it so i just left it as is, my pc build is in the works this crappy laptop will just have to do for now
(2020-11-06, 21:00)HugoL Wrote: [ -> ] (2020-11-06, 20:29)mathu204 Wrote: [ -> ]https://imgur.com/a/FDugKN8
That I am not getting I just checked with planet earth do I need to use a particular scraper? Im using tvdb
(2020-11-06, 21:02)mathu204 Wrote: [ -> ] (2020-11-06, 20:40)HugoL Wrote: [ -> ] (2020-11-06, 20:29)mathu204 Wrote: [ -> ]https://imgur.com/a/FDugKN8
i just checked in device manager and it says both are up to date, i have a intel hd 3000, and nvidia 4200M, but i checked my laptop model and it cant go to 1920x1080 unless i upgrade the screen so it is what it is.
(2020-11-06, 21:03)mathu204 Wrote: [ -> ] (2020-11-06, 21:02)mathu204 Wrote: [ -> ] (2020-11-06, 20:40)HugoL Wrote: [ -> ]Do you not have a 1920 x 1080p capable laptop?
so in the search menu, as you said cartman made a lot of preconfigured lists and now im liking library integration more and more, can i make custom lists that will show up in the search hub like that or is that the limit? Also where can i find more like that pre configured if possible or how can i make my own? Id like to find some premade if possible but ill learn how to customize it too if it comes down to it
