(2020-11-06, 21:05)mathu204 Wrote: [ -> ] (2020-11-06, 21:03)mathu204 Wrote: [ -> ] (2020-11-06, 21:02)mathu204 Wrote: [ -> ]no i dont think this laptop can, also idk how to change the monitor setting i cant click it or go to it so i just left it as is, my pc build is in the works this crappy laptop will just have to do for now
i just checked in device manager and it says both are up to date, i have a intel hd 3000, and nvidia 4200M, but i checked my laptop model and it cant go to 1920x1080 unless i upgrade the screen so it is what it is.
so in the search menu, as you said cartman made a lot of preconfigured lists and now im liking library integration more and more, can i make custom lists that will show up in the search hub like that or is that the limit? Also where can i find more like that pre configured if possible or how can i make my own? Id like to find some premade if possible but ill learn how to customize it too if it comes down to it
Your going down the rabbit hole now lol. Look up smart playlists and Tags.
(2020-11-06, 21:00)HugoL Wrote: [ -> ] (2020-11-06, 20:29)mathu204 Wrote: [ -> ]https://imgur.com/a/FDugKN8
here is the results but it never saves my changes @HugoL for resoltuion
Something must be up with your monitor driver. Pretty sure it shouldn't say "generic monitor". Check you have the right driver for your laptop monitor.
You are unable to select monitor because you have already selected it before and hit default.
It should only say generic if you are using a HDMI to your TV.
(2020-11-06, 21:02)cscott1 Wrote: [ -> ] (2020-11-06, 21:00)HugoL Wrote: [ -> ] (2020-11-06, 20:29)mathu204 Wrote: [ -> ]https://imgur.com/a/FDugKN8
That I am not getting I just checked with planet earth do I need to use a particular scraper? Im using tvdb
I use TVDB scraper for shows. Mines working but sure if this Top 250 is coming from the scraper or from skin helper (can’t even be sure if skin helper is working to be honest).
Just keep flicking through your shows to make sure the metadata doesn’t in fact just pop up.
If it doesn’t, you can use the addon Metadata editor to scrape all your ratings. Great tool! It’s on the Kodi repository.
yes monitor should only be like this if you defaulted it with HDMI to TV.
(2020-11-06, 21:07)cscott1 Wrote: [ -> ] (2020-11-06, 21:05)mathu204 Wrote: [ -> ] (2020-11-06, 21:03)mathu204 Wrote: [ -> ]i just checked in device manager and it says both are up to date, i have a intel hd 3000, and nvidia 4200M, but i checked my laptop model and it cant go to 1920x1080 unless i upgrade the screen so it is what it is.
Didn’t I read once that you made a load of smart playlists? Maybe you could send him some of your .xsp files to get him started.
(2020-11-06, 21:51)HugoL Wrote: [ -> ] (2020-11-06, 21:07)cscott1 Wrote: [ -> ] (2020-11-06, 21:05)mathu204 Wrote: [ -> ]so in the search menu, as you said cartman made a lot of preconfigured lists and now im liking library integration more and more, can i make custom lists that will show up in the search hub like that or is that the limit? Also where can i find more like that pre configured if possible or how can i make my own? Id like to find some premade if possible but ill learn how to customize it too if it comes down to it
Yeah I have a sh!t ton of them mine are very specific to my library but I'll make a tutorial video on setting up tags and smart playlists to help out.
(2020-11-06, 22:46)cscott1 Wrote: [ -> ] (2020-11-06, 21:51)HugoL Wrote: [ -> ] (2020-11-06, 21:07)cscott1 Wrote: [ -> ]Your going down the rabbit hole now lol. Look up smart playlists and Tags.
I might need to adjust the new releases in movies and tv as well. Change the date from 2017 to maybe 2019 inside the xsp
(2020-11-06, 21:45)HugoL Wrote: [ -> ] (2020-11-06, 21:02)cscott1 Wrote: [ -> ] (2020-11-06, 21:00)HugoL Wrote: [ -> ]Something must be up with your monitor driver. Pretty sure it shouldn't say "generic monitor". Check you have the right driver for your laptop monitor.
I added the metadata editor add-on and had to add in my omdb api I scaped all 788 tv shows I have more than I thought. Still no imdb top 250 for tv shows not sure why hopefully they just show up after a while like you mentioned.
(2020-11-06, 22:59)cscott1 Wrote: [ -> ] (2020-11-06, 21:45)HugoL Wrote: [ -> ] (2020-11-06, 21:02)cscott1 Wrote: [ -> ]That I am not getting I just checked with planet earth do I need to use a particular scraper? Im using tvdb
Yes they will take a while to show up. It will start pulling from the internet. I think mine took around 3 day's to start pulling in everything to be honest.
Back when CK77 was on here.
I think you've just got very terrible taste in TV shows and need to get some top 250 shows! Like this (since I've been wanting to rewatch this since lockdown!)....
In all seriousness, find a show you know is in the top 250 (like the above for example) and while focussed on it, just wait a while (although mine is instant to be fair). If you still don't see the label I'm going to have to check how else I might be scraping this info.
(2020-11-06, 23:42)HugoL Wrote: [ -> ] (2020-11-06, 22:59)cscott1 Wrote: [ -> ] (2020-11-06, 21:45)HugoL Wrote: [ -> ]I use TVDB scraper for shows. Mines working but sure if this Top 250 is coming from the scraper or from skin helper (can’t even be sure if skin helper is working to be honest).
I think the free omdb key says it can take up to 24hrs to start. After it kicks in it should be instant
(2020-11-06, 23:45)AchillesPunks Wrote: [ -> ] (2020-11-06, 23:42)HugoL Wrote: [ -> ] (2020-11-06, 22:59)cscott1 Wrote: [ -> ]I added the metadata editor add-on and had to add in my omdb api I scaped all 788 tv shows I have more than I thought. Still no imdb top 250 for tv shows not sure why hopefully they just show up after a while like you mentioned.
I don't even think IMDB info comes from OMDB anyway. I know this is scraped by the TMDB python scraper for movies. I can see the entry in my movies db. I think TV shows may be a different story (with my TVDB scraper at least) Either Skin helper is retrieving these, or Metadata Editor is doing it.
(2020-11-06, 21:49)AchillesPunks Wrote: [ -> ] (2020-11-06, 20:29)mathu204 Wrote: [ -> ]https://imgur.com/a/FDugKN8
Didn't you used to set this to 1080p and just let the TV do the upscaling?
Apparently, that's the best way as your TV will have a better upscaler than Kodi.
(2020-11-07, 00:02)HugoL Wrote: [ -> ] (2020-11-06, 21:49)AchillesPunks Wrote: [ -> ] (2020-11-06, 20:29)mathu204 Wrote: [ -> ]https://imgur.com/a/FDugKN8
That's My default resolution for the TV and kodi. I have to enable 1080 because it's a lower resolution for the TV.
It's a 8k tv but defaults in kodi to 4k 120hz
mathu204 here is a quick video to get you started with your tags and smart playlists... I was a couple beers in when I made it so I could have probably done a better job of outlining step by step for different kinds of playlists but just experiment I'm sure you will figure it out I did and I'm not the sharpest tool in the shed.
https://youtu.be/KwKrc94MiOw
