Full Version: How to add TMDBURL in mkv tags?
I would like to add a TMDBURL and title to the mkv metadata like it is mentioned in the wiki on 4.1: https://kodi.wiki/view/Video_file_tagging
So far I've created an xml file with 3 simple tags:
<?xml version="1.0" encoding="ISO-8859-1"?>
<!DOCTYPE Tags SYSTEM "matroskatags.dtd">
<Tags>
<Tag>
<Simple>
<Name>TITLE</Name>
<String>1984</String>
</Simple>
<Simple>
<Name>DATE_RELEASED</Name>
</Simple>
<Simple>
<Name>TMDBURL</Name>
<String>https://www.themoviedb.org/movie/9314-nineteen-eighty-four</String>
</Simple>
</Tag>
</Tags>
and embedded it with mkvpropedit --set title="1984" --tags all:1984.xml 1984\ (1984\).mkv
In Kodi I've enabled the option to use the video tags and the test file was added as a new file to the library. But the scraper still finds the wrong movie (43/84 1984 in this case).
I think I'm doing something wrong while adding the tags. Can someone give me a hint what I need to do?
Basically you can add any info you want to a MKV container file, but Kodi won't read/use it.
Kodi will either use an existing .nfo file, or use online data via the scraper.
(2020-07-27, 16:07)Klojum Wrote: [ -> ]Basically you can add any info you want to a MKV container file, but Kodi won't read/use it.
On the wiki it's described that the title and TMDBURL tag should work with *.mkv: https://kodi.wiki/view/Video_file_tagging
In the mean time I figured out the tags are set in the mkv file and are visible using ffprobe. The title tag is used also. If I set it to something different it will scrape using the title tag. But TMDBURL is still ignored. I would like to use the mention TMDBURL tag to guide the scraper to use this url for scraping.
At a guess the actual tag needs to be <TMDBURL>some_movie_url</TMDBURL>
(2020-07-27, 16:28)Malebolgia Wrote: [ -> ]On the wiki it's described that the title and TMDBURL tag should work with *.mkv
Oops.. my bad.
(2020-07-27, 16:40)jjd-uk Wrote: [ -> ]At a guess the actual tag needs to be <TMDBURL>some_movie_url</TMDBURL>
I'm not sure how to set this, because if I just add it to the xml it complains that the xml is not valid anymore because it doesn't know this tag. I think it must be escaped then.
I found the commit where this feature was added: https://github.com/xbmc/xbmc/commit/47bb...16c6fbR123
The TITLE tag is working, but TMDBURL is still ignored.
XML:
<?xml version="1.0" encoding="UTF-8"?>
<Tags>
 <Tag>
   <Simple>
     <Name>TITLE</Name>
     <String>The Empire Strikes Back</String>
   </Simple>
   <Simple>
   </Simple>
 </Tag>
</Tags>
File was renamed to noname.mkv.
ffprobe shows:
 Metadata:
   encoder         : libebml v1.3.0 + libmatroska v1.4.0
   creation_time   : 2016-11-14T05:46:24.000000Z
   TITLE           : The Empire Strikes Back
   TMDBURL         : https://www.themoviedb.org/movie/9314-ni...ighty-four
Kodi scrapes the file as "The Empire Strikes Back".
It was a pure guess based on https://github.com/xbmc/xbmc/blob/master...g.cpp#L116
The guy who added the code is not currently active, but it's possible he might respond to a ping @spiff
Another member had the same issue a few months ago... https://forum.kodi.tv/showthread.php?tid=351235
I guess the feature is buggy/broken.
