I getting the following error when trying to create Mariadb
Failed to enable unit: Unit file connman-wait-for-network.service does not exist
Followed the guide
These are my steps
https://pastebin.com/LwbHSHCE
Nothing comes up on my second device
I tried the following command
Sudo service Mariadb status and it says its running
https://pastebin.com/Q8KiwK64
Am I doing something wrong
Ubuntu 20.04
Kodi 18.8
What guide did you follow? That connman service is specific to OSMC AFAIK.
I've used MySQL databases on from Ubuntu 14.04 till 20.04 .
I never need to use something like a wait-for-network option.
Why do you need it?
(2020-07-31, 23:54)black_eagle Wrote: [ -> ]What guide did you follow? That connman service is specific to OSMC AFAIK.
I followed
https://kodi.wiki/view/MySQL
my pastebin is each step I did and then copied the Advancedsettings.xml (in pastebin also) to both devices
But nothing comes up on the second device.
Both fresh installs
(2020-08-01, 00:05)Klojum Wrote: [ -> ]I've used MySQL databases on from Ubuntu 14.04 till 20.04 .
Why do you need it?
Maybe I'm missing something
I've copied the same Advancedsettings.xml in the pastebin in each device but no media is shown on my second device.
(2020-08-01, 03:26)Yoshifriend Wrote: [ -> ]Maybe I'm missing something
Maybe you're just overthinking things.
(2020-08-01, 03:26)Yoshifriend Wrote: [ -> ]I've copied the same Advancedsettings.xml in the pastebin in each device but no media is shown on my second device.
"No media" is a bit vague to me. I see it as 3 separate things: creating a database, accessing a database locally, using the database with Kodi.
Perhaps that
Failed to enable unit: Unit file connman-wait-for-network.service does not exist is a MariaDB thing, I just haven't encountered it before.
You could try to do:
systemctl disable systemd-networkd-wait-online.service
to disable the wait-online service to prevent the system from waiting on a network connection, and use
systemctl mask systemd-networkd-wait-online.service
to prevent the service from starting if requested by another service (the service is symlinked to /dev/null).
But again, I never have such network troubles with Ubuntu, including 20.04.
If you reboot your Ubuntu pc, and open a terminal and type
mysql
, what happens? It should get you into the mysql console.
You should also be able to log in with Kodi's credentials, using tools like MySQL Workbench or PHPMyAdmin.
Thirdly, there is the filling up of the Kodi database with data.
Quote:I've copied the same Advancedsettings.xml in the pastebin in each device but no media is shown on my second device.
So where exactly is the message "no media" coming from?
Also provide a full kodi.log the problematic device.
Quote:"No media" is a bit vague to me. I see it as 3 separate things: creating a database, accessing a database locally, using the database with Kodi.
Apologies I mean I can see the movies on computer with Mariadb installed on it but can't see movies on the second device.
I installed Mariadb first then added a movie source. Also tried removing source and adding it again
If you reboot your Ubuntu pc, and open a terminal and type mysql
I input those 2 commands in then opened kodi on both devices but still can't see movies on 2nd device
When I type mysql in command I get
Error 1045 (28000):access denied for user 'user'@localhost' (using password: NO)
Edit:
I removed everything and started from start and did the following steps
Put new movie source
I haven't got any errors but again I can't see the movie source on my second device.
Are my step in the pastebin correct?
Yoshifriend Please post a link to a
debug log (wiki) from the second device. Please make sure you follow all the instructions in this link ->
debug log (wiki)
Quote:<advancedsettings version="1.0">
<videodatabase>
<type>mysql</type>
<host>192.168.1.162</host>
<port>3306</port>
<user>kodi</user>
<pass>*****</pass>
</videodatabase>
vs.
Quote:bind-address = 192.168.1.10
Are you sure you know what you are doing? You have to place the server IP into the setting, not the client one, your kodi config is wrong.
(2020-08-02, 09:09)fritsch Wrote: [ -> ]Quote:<advancedsettings version="1.0">
<videodatabase>
<type>mysql</type>
<port>3306</port>
<user>kodi</user>
<pass>*****</pass>
</videodatabase>
vs.
No I've tried another pc to test thats why I wrote the pc running kodi is 192.168.1.162.
Disregard 192.168.4.10
According to your log, your device does connect to mariadb.
Quote:
2020-08-02 09:33:12.989 T:4559 NOTICE: MYSQL: Connected to version 10.3.22-MariaDB-1ubuntu1
But then I noticed
Quote:2020-08-02 09:33:13.864 T:4445 NOTICE: UpdateLibraries: Starting video library startup scan
Unless you have copied the sources.xml file (and possibly mediasources.xml) to that device, I doubt that updating the library with it on startup is a good idea.
(2020-08-03, 14:13)Yoshifriend Wrote: [ -> ]No I've tried another pc to test thats why I wrote the pc running kodi is 192.168.1.162.
The address needs to be the address of the PC or device running mariadb, although the log does show it connecting.
If you do
mysql -u kodi -p
and then enter the password from your advancedsettings,xml file then that should log you into mariadb as the kodi user. Then do
show databases;
to check that the db's exist.
Then you could try
use MyVideos116;
followed by
select * from movie where idMovie = 1;
and ensure it returns some data.
Added in source. Xml file and same issue
(2020-08-03, 21:27)black_eagle Wrote: [ -> ]If you do mysql -u kodi -p
and then enter the password from your advancedsettings,xml file then that should log you into mariadb as the kodi user. Then do show databases;
Then you could try use MyVideos116;
followed by select * from movie where idMovie = 1;
It says
Empty set (0.001 sec)
https://pastebin.com/2aq0KBxj
I'm adding a database like normal by going to video
Add video
Add source
Directory contains movie
Movies scan and show up on computer
Nothing on android phone
Based off that, my guess right now is that your PC is still using sqlite for it's database, not mariadb. Please post a
Debug Log of Kodi starting up on the PC. Make sure you start it, put it into debugging then quit and restart it. Post the log from the restart please.
