Full Version: Kodi on X96 Steraming Box - copied video files missing?
Hi guys,
Ive looked on the boards but can't seem to find an issue thats the same as mine so I thought I would ask for some help or advice.
I am running Kodi Leia on an Android box - an X96 to be exact. Its connected via hardwire to my home network, and I also have a uPNP WD MyCloud 4tb drive connected to the same network, with another WD MyBook 3tb disk attached via USB.
I am having a strange problem - when I copy some content to the shared folder on the uPNP drive from my laptop, I can see it in windows but even when I have updated the library there are files that do not show. The drive on my laptop is shared, with full control and they are not read-only.
This has been happening with only certain files, with no discernible pattern to file types or sizes.
Could I ask for some advice please?
PR
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
4.Upload the log to Kodi Paste Site manually or use the Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file (wiki)
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
