2021-01-03, 00:21
(2021-01-02, 20:46)pkscout Wrote: [ -> ]... so I'm not sure why stock Estuary has that option and this mod doesn't.Propably its visibla just in boxes with dual boot.
But thank You in advance.
(2021-01-03, 00:21)Juno Wrote: [ -> ]The menu for the power button is defined in DialogButtonMenu.xml. I've compared the one in stock Estuary and my mod. They are identical. The only thing I can figure is that your Kodi install is a slightly modified version of Kodi that includes that extra menu. Sometimes platform specific builds do that.(2021-01-02, 20:46)pkscout Wrote: [ -> ]... so I'm not sure why stock Estuary has that option and this mod doesn't.Propably its visibla just in boxes with dual boot.
(2021-01-03, 00:29)pkscout Wrote: [ -> ]Estuary CE shutdownmenu(2021-01-03, 00:21)Juno Wrote: [ -> ]The menu for the power button is defined in DialogButtonMenu.xml. I've compared the one in stock Estuary and my mod. They are identical. The only thing I can figure is that your Kodi install is a slightly modified version of Kodi that includes that extra menu. Sometimes platform specific builds do that.(2021-01-02, 20:46)pkscout Wrote: [ -> ]... so I'm not sure why stock Estuary has that option and this mod doesn't.Propably its visibla just in boxes with dual boot.
(2021-01-11, 17:21)uVSthem Wrote: [ -> ]I cannot get to the context menu to select artwork. I do not see the button in the info page for it. Is there something I need to install to get it to show up?
(2021-01-11, 18:23)pkscout Wrote: [ -> ]Thanks you for the reply. It is there with normal Estuary so I'm not what is going on with the mod. Do you know the best way I get go back to a "factory default" setting without losing my entire library?(2021-01-11, 17:21)uVSthem Wrote: [ -> ]I cannot get to the context menu to select artwork. I do not see the button in the info page for it. Is there something I need to install to get it to show up?
There is a choose artwork button on every info screen I checked.
That set of stuff was not touched from the original Estuary, so you might want to check and see if the problem persists if you use the stock skin.
(2021-01-11, 18:56)uVSthem Wrote: [ -> ]You can delete the settings.xml file in userdata/addon_data/skin.estuary.matrix.pkscout.mod. That would reset the skin back to it's default settings. I'll be a little surprised if that helped since, again, the code that generates that info page is 100% the same as stock Estuary. But let's see what happens.(2021-01-11, 18:23)pkscout Wrote: [ -> ]Thanks you for the reply. It is there with normal Estuary so I'm not what is going on with the mod. Do you know the best way I get go back to a "factory default" setting without losing my entire library?(2021-01-11, 17:21)uVSthem Wrote: [ -> ]I cannot get to the context menu to select artwork. I do not see the button in the info page for it. Is there something I need to install to get it to show up?
(2021-01-23, 03:12)emveepee Wrote: [ -> ]@pkscout would there be any change for your Estuary mod that would enable the traditional seek bar on the bottom half of the OSD? I don't need to read sub-titles in PVR Recordings and I just can't get used to the look and feel of the top scroll bar.I didn't even realize the seek bar had moved in the Matrix version of Estuary (I'm using Arctic Horizon for day to day use now). I'd hadn't planned to make any further changes, but let me see how hard it would be to have an option to use the old OSD.
Martin
(2021-01-23, 18:55)pkscout Wrote: [ -> ](2021-01-23, 03:12)emveepee Wrote: [ -> ]@pkscout would there be any change for your Estuary mod that would enable the traditional seek bar on the bottom half of the OSD? I don't need to read sub-titles in PVR Recordings and I just can't get used to the look and feel of the top scroll bar.I didn't even realize the seek bar had moved in the Matrix version of Estuary (I'm using Arctic Horizon for day to day use now). I'd hadn't planned to make any further changes, but let me see how hard it would be to have an option to use the old OSD.
Martin
(2021-01-23, 03:12)emveepee Wrote: [ -> ]@pkscout would there be any change for your Estuary mod that would enable the traditional seek bar on the bottom half of the OSD? I don't need to read sub-titles in PVR Recordings and I just can't get used to the look and feel of the top scroll bar.v 1.0.6 is in my skin repo now and has a toggle switch in the general skin settings to show the seekbar at the bottom instead. I didn't do anything to try and move any active captions, so that'll still be an issue. But it was an issue in Leia anyway, so I think what I did just gives you the option to have it work the way it did in Leia, warts and all.
Martin
(2021-01-26, 01:27)emveepee Wrote: [ -> ]Works great thanks a lot @pkscout I appreciate you taking the time since I know you don't use Estuary anymore. The support for the bigger space for major/minor channel numbers is a bonus.Yea, I noticed that while testing. I thought I had fixed all those, so I snuck that in too.
Martin
