Full Version: LibreELEC (official): 9.2.3 Rasbian RPi 4 kodi does not work
Hello!
I have an RPi 4 device connected to TV (Samsung UE46ES6550) by HDMI, installed LibreELEC (official): 9.2.3
When the device starts up, only "LibreELEC (official): 9.2.3" is displayed (and the logo is something like that) and the download stops.
Chose another way:
Rasbian is installed on the RPI 4.
Installed Kodi, according to the forums and instructions, you need to add the dtoverlay = vc4-fkms-v3d parameter to config.txt.
When adding a parameter and loading Rasbian, I get a black TV screen (No signal). Without this parameter, the system boots, but kodi refuses to start. (unable to create gui )
Tell me, can anyone come across this issue.
Please help, have any ideas?
config.txt:
disable_overscan=1
dtparam=audio=on
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
hdmi_force_hotplug=1
hdmi_ignore_edid=0xa5000080
gpu_mem=256
kodi.log:
mod edit - log spam moved to https://paste.kodi.tv/wuroqiyodo.kodi
As per the big red banner above the posting buttons, please do not spam the form with logs. That is what we have a paste site for...
(2020-08-12, 09:28)Balast5 Wrote: [ -> ]Rasbian is installed on the RPI 4.
dtoverlay=vc4-fkms-v3d is the default setting of a clean PiOS (formerly named raspbian) install.
Are you saying a fresh PiOS sdcard (without your config.txt edits) produces a black screen?
(2020-08-12, 12:27)popcornmix Wrote: [ -> ]
yes, without confugure config.txt, after install fresh Raspbian I get black screen.
(2020-08-12, 12:50)Balast5 Wrote: [ -> ]yes, without confugure config.txt, after install fresh Raspbian I get black screen.
Raspbian is  now called Raspberry Pi OS. Can you confirm issue still occurs with latest version:
https://www.raspberrypi.org/downloads/raspberry-pi-os/
and if so create an issue here: https://github.com/raspberrypi/firmware/issues
You're problem isn't with kodi if you get a blank screen with the default PiOS install.
Solve that first, then try kodi again.
(2020-08-12, 13:02)popcornmix Wrote: [ -> ]
Ok, thanks for information.
