Full Version: why is "uninstall" grayed out?
the option to uninstall tajo appears grayed out, there are only 2 options available and neither of them will let me exit...
as it stands there is no access to the traditional kodi settings menu (settings -> addons -> uninstall ...i understand that this is the suggested fix but that "settings" menu is inaccessible with tajo installed) and the only way i can restore to default is to factory
any explanations?
You cannot uninstall a skin that is in use.
You need to swap skins, say back to the default Estuary skin, then you can uninstall it. Then be sure to uninstall the dependencies that were installed with it.
Better to just leave it disabled. Why do you want to uninstall it?
