Hello,
since version 9.2.4.2 I have a problem with film covers / summaries which always displays in English instead of French.
However, I checked on the site “themoviedb.org” and the film is in French…
Is there a trick to digitize the cover / summary of the film in FR ? the option is already in FR in the extension but it does not work.
Thank you for your help.
Best regards
Can you provide the links from TheMovieDB to two movies that you are having problems with.
We don't have a version 9.2.4.2, so not sure where you are looking.
@akuruilop
I cannot replicate the problem you describe. I tested the first two movies and they both scraped French...
Can you post a screenshot of your scraper settings page.
Alternatively, switch to the new TheMovieDB-Python scraper which you can download using the "Get More" button. See if you have any better luck with the new scraper.
(2020-08-18, 23:46)Karellen Wrote: [ -> ]@akuruilop
thank you for your reply. Here are the photos of my TV with the films and settings. It's very strange and I don't understand why everything doesn't go into FR :
https://ibb.co/kxr9hNZ
https://ibb.co/2txNJGN
https://ibb.co/jwfk807
Ok, that is strange. I can see nothing wrong with your settings.
Can you delete two of those movies from your library, then create a
Debug Log that captures you scraping them back into your library.
Hopefully I will spot what the problem is in the log.
I just tested the new scrap in python and everything is in error. No scraped film.
I even just did a fresh install but same problem.
Thanks for your help.
https://ibb.co/72WF2V9
(2020-08-19, 10:53)Karellen Wrote: [ -> ]Ok, that is strange. I can see nothing wrong with your settings.
Can you delete two of those movies from your library, then create a Debug Log that captures you scraping them back into your library.
The problem now occurs on other movies:
https://www.themoviedb.org/movie/75-mars...anguage=fr
Can I send you the logs privately ?
(2020-08-19, 11:04)akuruilop Wrote: [ -> ]Can I send you the logs privately ?
Sure. You are still a newbie, so you cannot PM yet.
Instead underneath my post to the right you will see the
Report button. Click it, select
Other then paste the link to the log.
Use
Kodi Paste Site to paste the log and provide the link. Make sure you enabled debug mode in Settings>System settings>Logging, then restarted Kodi and scraped the movies.
(2020-08-19, 11:07)Karellen Wrote: [ -> ] (2020-08-19, 11:04)akuruilop Wrote: [ -> ]Can I send you the logs privately ?
Instead underneath my post to the right you will see the Report button. Click it, select Other then paste the link to the log.
Use Kodi Paste Site to paste the log and provide the link. Make sure you enabled debug mode in Settings>System settings>Logging, then restarted Kodi and scraped the movies.
I don't see the report button below your message ...
(2020-08-19, 11:14)akuruilop Wrote: [ -> ]I don't see the report button below your message ...
(2020-08-19, 11:21)Karellen Wrote: [ -> ] (2020-08-19, 11:14)akuruilop Wrote: [ -> ]I don't see the report button below your message ...
Thanks for your help. I just sent you the report of two new films in English.
i can't send the whole report, there is too much line, pastbin don't take it ...
How can it not take it? It accepts around 18,000 lines of log. You have given me one log with 41 lines another log with 82 lines.
Don't give me what you think I need, give me the full log.
Also there is nothing revealing in your logs. There is no personal information, so please post the links here in the forum. Because as soon as I close the pages, I have lost your logs and there is no way for me to find them again.
