2020-08-20, 03:34
I've read through the wiki and have browsed my different shows on TMDB and found the names/patterns. However during this process, I spent several hours messing with Powershell tutorials but none of them were specific and I figured there had to be something here for renaming a folder's content to coincidence with the database's metadata pattern.
My problem is though, to rename the shows, I need to tell the script I'm running WHICH shows happen to be episode 1, and so on, so it can rename them to the appropriate pattern sequentially. I tried running a script I ran made for Kodi to do this but it was a few years old and I didn't have good luck. Just checking to see if there is an easier way.
