Full Version: 'Server does not respond properly' after reboot.
*** Solved ***
See https://forum.libreelec.tv/thread/22549-...er-reboot/ for more info.
I first noticed the issue after (during?) installing 'service.sabnzbd-9.2.0.35.zip' via 'Install from zip file'.
Sabnzbd has 'locale' as dependency.
The issue didn't change after removing both 'sabnzbd' and 'locale'.
After every reboot I see a message in Kodi that Tvheadend Client: 'Server does not respond properly'.
Live-TV is not working after this.
(systemctl stop kodi, systemctl start kodi doesn't change the situation)
If I go to Add-ons > My add-ons > Services > select Tvheadend Server 4.2 > Configure > OK (without any changes) it starts to work.
Tvheadend Client: Connection Established
I have not yet tried to re-install Tvheadend.
Steps performed for taking logging:
reboot
wait ~5 min
made TVH work normally
log-2020-08-21-18.25.02_TVH_working_normally.zip
wait ~5 min
reboot
wait ~5 min
log-2020-08-21-18.37.07_TVH_problem_situation.zip
Looking at the TVH logs:
Based on the timestamp, the TVH logging looks to start only after making TVH work (log-2020-08-21-18.25.02_TVH_working_normally.zip\11_Addons.log).
# ... output of cat /storage/.kodi/userdata/addon_data/service.tvheadend42/service.log
# LibreELEC release: RPi2.arm-9.2.3
2020-08-21 20:24:22.533 [   INFO] main: Log started
The first logs on TVH during the problem state looks weird. (log-2020-08-21-18.37.07_TVH_problem_situation.zip\11_Addons.log)
They are from 2019-04-11, and look to be from a previous installation.
LE-9.2.3 was written to this 128GB card LibreELEC.USB-SD.Creator.Win32.exe.
I didn't format this card before doing that.
Can this be due to a corrupted filesystem?
LE-9.2.3
TVH Server 4.2, Team LE 9.2.0.122
TVH Client, 4.4.21.1
