When an error message count shows up on the bottom right, it's not easy to click on it because a tooltip box covers it when you move the cursor onto it.
To open the error message, you have to move the mouse real quick and click on it before the tooltip shows up.
strange behavior - but I've seen that this is an issue in v3 AND v4 -> and both versions use different UI engines, so I suppose this is something by design?
I'll contact an UI specialist
I've created a workaround in v4 for that issue
