Full Version: Ember cant scan movies folder
Hi
I did install Ember on newly Win 10 PC
And i added the folders in the setting but Every time i click update the library only 14 movies show up from 1200 movies !
It work great in older pc but the new is no
I did tried many versions of ember but none of them worked
I need help what i could missed that stopping ember to all show movies
The installed version is 1.5
Plaes post the log (.\Ember Media Manager\Logs\*.csv) after a scan on pastebin.com.
What settings did you use to add the source?
(2020-08-26, 11:32)DanCooper Wrote: [ -> ]Plaes post the log (.\Ember Media Manager\Logs\*.csv) after a scan on pastebin.com.
I used default nothing changed
https://pastebin.com/Zm1YPBdq
