Full Version: Internet radio streaming freeze
I have problems with playing internet radio streams. My Kodi often crash if I try to play radio station streams.
If I play music, for example, with MP3 stream or Bandcamp, that's no problem. It is only with internet radio streams (RADIO ADDON)
I have Kodi Leia/Libre Elec last version on a Intel NUC mini PC.
Maybe someone recognize the problem.
On my other computer with almost the same configuration there is no problem......
Thanks for the input in advance !
Unfortunately, my crystal ball is broken at the moment.  Therefore, I'd suggest you upload and link a Debug Log that captures this crashing issue  otherwise no-one will have any clue what might be causing it Smile
PROBLEM SOLVED !!!!
(2020-09-16, 11:44)Gijsje117 Wrote: [ -> ]PROBLEM SOLVED !!!!
Well that's great but would you like to elaborate on how you solved it, so that others with a similar issue can benefit too ?
