Do anyone know why I get errro for this function that it's not implemented? (v18)
python:
xbmcgui.WindowDialog.setCoordinateResolution(0) # 1920x1080
It located here:
python:
class PlayerWindow(xbmcgui.WindowDialog):
def __init__(self):
self.setCoordinateResolution(0) # 1920x1080
php:
ERROR: EXCEPTION: not implemented.
ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.RuntimeError'>
Error Contents: not implemented.
File "D:\Program Files (x86)\Kodi v18.6 x64\portable_data\addons\script.100\addon.py", line 17, in <module>
player_window = PlayerWindow()
File "D:\Program Files (x86)\Kodi v18.6 x64\portable_data\addons\script.100\player.py", line 21, in __init__
RuntimeError: not implemented.
Thanks @
ronie
So there is an alternative to this function in v18?
Because the addon looks bad without it, like this:
Instead of like this:
hmm.. i've never very little experience with Window/WindowDialog classes, but what i did was this:
python:
self.WINID = xbmcgui.getCurrentWindowId()
self.win = xbmcgui.Window(self.WINID)
width = self.win.getWidth()
height = self.win.getHeight()
that will get you the width & height of the window.
and then dynamically calculate the size & position of all controls based on that info.
perhaps @
Roman_V_M has a better idea.
Thread moved to addon development
ronie
Roman_V_M
Basically all the controls size & position are already fixed and adjusted to 1920 X 1080.
Also the functions that you mentioned here give me this resolution of the window.
So I still don't understand why does it still show it differently
without using the 'WindowDialog.setCoordinateResolution' function which is not exist in v18 anymore.
then i'm in the dark as well...
perhaps the skin you're using is 720p ?
ronie
Yes, you right! Thanks.
I made some resolution converting functions, I convert all the sizes & positions according to 1280 X 720 and it works, all the controls are in place.
But I still don't understand if the win.getWidth() and win.getHeight() functions give me 1080 X 1920, why the addon need to convert it to 1280 X 720?
Now I understand why this function was so important to be there:
python:
How I can get this resolution sizes dynamically for each skin? (Currently I told to convert it to 1280 X 720 fixed inside the code)
Also where can I check the skin resolution?
From what I know it 1080 (according to the folder in the skin addon folder, and as it shown in the Settings)
(2020-08-31, 15:51)burekas Wrote: [ -> ]Also where can I check the skin resolution?
that is what my code is supposed to do (although i mistakenly said it returns the window size)
i just tested it in Confluence (a 720p skin) and the code correctly returns 1280 / 720
then tested it in Estuary (which is coded in 1080) and the code now returns 1920 / 1080
So it's strange.
My skin return 1080 resolution, but the addon still required to adjust the controls to 720 resolution, so the skin resolution has no affect on the addon coordinates.
in v17, this old function forced the addon to be 1080 so all the sizes and positions was set according to that.
and which skin would that 'My skin' be?
By default Window and WindowDialog classes operate on 1280x720 coordinate grid. It does not depend on the current skin or the actual display resolution.
Previously getWidth/getHeight returned the current display resolution which was confusing. Now they return the coordinate grid resolution. However, it looks like now we don't have a way to set a coordinate grid resolution that may be useful in some cases. I plan to fix it in the upcoming "Matrix" version as soon as I get some free time.
Roman_V_M
Thank you for this detailed answer.
Now it's clear.
Roman_V_M will this solution add possibility for script addons to change the aspect ratio / resolution of shiped skins? I can't find a useful way to scale my custom skins.
16:9
21:9 Scaling is really bad.
