Hey Guys
Not sure how or where to post this issue and am ignorant on the subject, but will start here.
There are several streams that will not play for me in Kodi 18.8/Windows 7 but will play in Perfect Player IPTV on Android. Some of them did however need the decoder to be changed to Native or HW+
For instance, the publicly available NASA channels will not play for me on Kodi but will with Perfect Player IPTV on Android on a smartphone. Obviously I want to use Kodi.
That is the full extent of my knowledge, can anyone put me on the right track if that is fixable in Kodi.
If you have a test stream I can access from Ireland I can try and take a look.
From a recent issue with pvr.nextpvr I found those streams had many layers of playlist calling a playlist, not sure how many inputstream allows but I think those are 4 deep.
Martin
I have two other open streams below that are likely geolocked to Canada that won't play in Kodi but will in Perfect Player. I think, thus far, I've learned IPTV Simple Client won't play streams that don't end in m3u8? If so, is there a solution or a way to convert the streams to m3u8 or make them able to open in IPTV Simple Client.
#EXTINF:-1 tvg-logo="https://github.com/geonsey/Free2ViewTV/blob/master/images/logos/CTVNewsChannel_320x320.png?raw=true" group-title="News & Weather",CA | CTV News Channel
https://pe-ak-lp02a-9c9media.akamaized.n...t.mpd?News
#EXTINF:-1 tvg-logo="https://github.com/geonsey/Free2ViewTV/blob/master/images/logos/CP24_400x400.png?raw=true" group-title="News & Weather",Canada | CP24 Toronto
https://pe-ak-lp01a-9c9media.akamaized.n...t.mpd?News
Do you have inputstream adaptive installed for mpd playlists? I use Matrix and they play for me
Martin
(2020-09-09, 02:47)emveepee Wrote: [ -> ]Do you have inputstream adaptive installed for mpd playlists? I use Matrix and they play for me
I have InputStream adaptive installed, how do I know if it is for mpd playlists. I am using 18.8
(2020-09-09, 03:48)barney63 Wrote: [ -> ]I have InputStream adaptive installed, how do I know if it is for mpd playlists. I am using 18.8
That is why a proper support post requires logs.
Martin
(2020-09-09, 04:54)emveepee Wrote: [ -> ] (2020-09-09, 03:48)barney63 Wrote: [ -> ]I have InputStream adaptive installed, how do I know if it is for mpd playlists. I am using 18.8
Martin
So if I am interpreting this correctly, to fix the issue I have to install software that is in an alpha state and does not fully support many addons as of yet?
No you aren't interpreting what I have posted correctly. Setting up a test here in Canada on Matrix was easy so I thought that might be useful for you to know. The version you want to use is your choice. If you want support you simply need to provide the appropriate information according to the forum rules
https://kodi.wiki/view/Forum_rules#Posting With that someone might be able to help you and tell you if a fix is needed or not and whether it is going to be possible in Leia
Martin
Thanks, that's all I needed to know.
By following
this post (instructions below) I was able to regain some streams that once worked and then stopped (streams are below). Not sure if they stopped working when I upgraded to 18.8 or not.
(Leia 18.8) PVR IPTV Simple Client - Settings - General Tab - Change User-Agent - Type in
Windows
(Matrix 19 Alpha)
PVR IPTV Simple Client - Settings - Advanced Tab
- Channel Defaults
- User-Agent - Type in
Windows
I will have to do some reading on User-Agents and why this worked
#EXTINF:-1 tvg-logo="https://raw.githubusercontent.com/geonsey/Free2ViewTV/master/images/logos/OlympicChannel.png" group-title="Olympic Channel",Olympic Channel 1 | 1080p
https://ott-live.olympicchannel.com/out/u/OC1_1.m3u8
#EXTINF:-1 tvg-logo="https://raw.githubusercontent.com/geonsey/Free2ViewTV/master/images/logos/OlympicChannel.png" group-title="Olympic Channel",Olympic Channel 2 | 1080p
https://ott-live.olympicchannel.com/out/u/OC2_1.m3u8
#EXTINF:-1 tvg-logo="https://raw.githubusercontent.com/geonsey/Free2ViewTV/master/images/logos/OlympicChannel.png" group-title="Olympic Channel",Olympic Channel 3 | 1080p
https://ott-live.olympicchannel.com/out/u/OC3_1.m3u8
Hello guys, I know it's an old post but I'm looking for help when it comes to Which of these IPTV boxes are perfect for Kodi? It's a dutch site, but the boxes should be recgnonize
(2021-05-01, 12:03)Robvar23 Wrote: [ -> ]Hello guys, I know it's an old post but I'm looking for help when it comes to Which of these IPTV boxes are perfect for Kodi? It's a dutch site, but the boxes should be recgnonize
Your post appears completely unrelated this post. Why post it here?
