2008-08-08, 23:03
I did what I was recommended to do and I tried to backport the latest night build for gutsy to Mepis under the same environment I described in the previous post:
http://forum.xbmc.org/showthread.php?tid=35622
I looked fot that libmad library in my system and I found those:
I would really appreciate if somebody could point me out how to solve this problem.
Thank you very much for your time
gcc -DHAVE_CONFIG_H -I. -I. -I. -DFPM_INTEL -DASO_ZEROCHECK -Wall -march=i486 -g -O -fforce-addr -fthread-jumps -fcse-follow-jumps -fcse-skip-blocks -fexpensive-optimizations -fregmove -fschedule-insns2 -fstrength-reduce -MT huffman.lo -MD -MP -MF .deps/huffman.Tpo -c huffman.c -fPIC -DPIC -o huffman.o >/dev/null 2>&1
/bin/sh ./libtool --mode=link gcc -Wall -march=i486 -g -O -fforce-addr -fthread-jumps -fcse-follow-jumps -fcse-skip-blocks -fexpensive-optimizations -fregmove -fschedule-insns2 -fstrength-reduce -o libmad.la -rpath /usr/local/lib -version-info 2:1:2 version.lo fixed.lo bit.lo timer.lo stream.lo frame.lo synth.lo decoder.lo layer12.lo layer3.lo huffman.lo
gcc -shared .libs/version.o .libs/fixed.o .libs/bit.o .libs/timer.o .libs/stream.o .libs/frame.o .libs/synth.o .libs/decoder.o .libs/layer12.o .libs/layer3.o .libs/huffman.o -march=i486 -Wl,-soname -Wl,libmad.0 -o .libs/libmad.0.2.1
(cd .libs && rm -f libmad.0 && ln -s libmad.0.2.1 libmad.0)
(cd .libs && rm -f libmad && ln -s libmad.0.2.1 libmad)
ar cru .libs/libmad.a version.o fixed.o bit.o timer.o stream.o frame.o synth.o decoder.o layer12.o layer3.o huffman.o
ranlib .libs/libmad.a
creating libmad.la
(cd .libs && rm -f libmad.la && ln -s ../libmad.la libmad.la)
make[5]: Leaving directory `/home/marcos/packages/DEB-xbmc/xbmc-2.1a2svn14729/xbmc/cores/dvdplayer/Codecs/libmad'
make[4]: Leaving directory `/home/marcos/packages/DEB-xbmc/xbmc-2.1a2svn14729/xbmc/cores/dvdplayer/Codecs/libmad'
make[3]: Leaving directory `/home/marcos/packages/DEB-xbmc/xbmc-2.1a2svn14729/xbmc/cores/dvdplayer/Codecs/libmad'
cp libmad/.libs/libmad.so ../../../../system/players/dvdplayer/libmad-i486-linux.so
cp: cannot stat `libmad/.libs/libmad.so': No such file or directory
make[2]: *** [../../../../system/players/dvdplayer/libmad-i486-linux.so] Error 1
make[2]: Leaving directory `/home/marcos/packages/DEB-xbmc/xbmc-2.1a2svn14729/xbmc/cores/dvdplayer/Codecs'
make[1]: *** [dvdcodecs] Error 2
make[1]: Leaving directory `/home/marcos/packages/DEB-xbmc/xbmc-2.1a2svn14729'
/usr/lib/libmad.a
/usr/lib/libmad.la
/usr/lib/libmad.so
/usr/lib/libmad.so.0
/usr/lib/libmad.so.0.2.1
