2020-09-06, 12:58
I have a problem with the onup behaviour. The situation is like so:
A grouplist with skinshrtcuts widgets. I want to have specific onup conditions. The problem ist, that e.g. the <onup>300</onup> isn't working in the skinshortcuts widgets. It does nothing and i don't know, why
Grouplist
Widget 1
Can someone help?
Grouplist
xml:<control type="grouplist" id="301">
<height>770</height>
<orientation>vertical</orientation>
<bottom>188</bottom>
<width>2385</width>
<scrolltime tween="quadratic">400</scrolltime>
<usecontrolcoords>true</usecontrolcoords>
<itemgap>0</itemgap>
<!-- Widget 1 -->
<include>skinshortcuts-template-widget-vertical.1</include>
<!-- Widget 2 -->
<include>skinshortcuts-template-widget-vertical.2</include>
<!-- Widget 3 -->
<include>skinshortcuts-template-widget-vertical.3</include>
</control>
Widget 1
xml:<other include="widget-vertical.1">
<property name="id" tag="mainmenuid" />
<controls>
<control type="group" id="301$SKINSHORTCUTS[id]21">
<control type="grouplist">
</control>
</control>
<control type="$SKINSHORTCUTS[widgetlisttype]" id="301$SKINSHORTCUTS[id]1">
<onup>300</onup>
<visible>Integer.IsGreater(Container(301$SKINSHORTCUTS[id]1).NumItems,0) | Container(301$SKINSHORTCUTS[id]1).IsUpdating</visible>
<skinshortcuts>visibility</skinshortcuts>
<include content="TemplateItemLayout">
<param name="shortcutsid" value="301$SKINSHORTCUTS[id]1" />
</include>
<include content="TemplateFocusLayout">
</include>
<content limit="$VAR[DefWidgetLimit]" target="$SKINSHORTCUTS[target]" sortby="$SKINSHORTCUTS[sortby]" sortorder="$SKINSHORTCUTS[sort]">$SKINSHORTCUTS[content]</content>
</control>
</controls>
</other>
Can someone help?
