THANKS! for your continued support of this addon @
anxdpanic
I have an issue with a lot of videos since appr. 1 or 2 weeks. It was working like a charm for months now.
Running Kodi 18.8 and Youtube addon 6.8.4.
API keys created.
I already tried to remove the
access_manager.json and signed in again because this fixed some issues in the past, but no luck this time.
Some videos are working fine, but a lot don't (e.g.
https://www.youtube.com/watch?v=SYiNUkHiiL4).
I get the following error message in the log:
https://paste.kodi.tv/idufonuper.kodi
Since nobody is writting about that, it seems like a personal issue with my installation. Any suggestions?
Today I started getting an error whenever I try to add a video to the "Watch Later" playlist, the addon just says "Error: Playlist not found".
I was using 6.8.3 with automatic updates disabled. I updated manually to 6.8.4 but the problem persists.
The only two messages that appear in the log when this happens are:
ERROR: [plugin.video.youtube] Error reason: |playlistNotFound| with message: |Playlist not found.|
WARNING: Attempt to use invalid handle -1
Everything else seems to be working correctly. Any suggestions?
(2020-09-12, 02:22)mklopez Wrote: [ -> ]Today I started getting an error whenever I try to add a video to the "Watch Later" playlist, the addon just says "Error: Playlist not found".
Same here. Although the error did not start yesterday - it has been intermittently happening during this whole week while still allowing to add selected video to Watch Later after multiple attempts, e.g. 3 errors, then 4th attempt succeeds. Sometimes first attempt was successful.
Starting today all attempts fail with the message @
mklopez mentioned above. This is Kodi 17.6. Originally was on youtube addon 6.8.3. Upgraded today to 6.8.4 - no improvements.
Same problem here, Kodi 18.8, Youtube 6.8.3
Yesterday I noticed new searches with international characters in them no longer work. Saved searches with international characters work fine. The log snippet showing the error is
here.
I run the latest YouTube plugin v6.8.4 on Kodi 18.8.0 on CoreELEC 9.2.4.2.
(2020-09-11, 17:56)sam.roscoe Wrote: [ -> ]Hi,
API keys created.
I already tried to remove the access_manager.json and signed in again because this fixed some issues in the past, but no luck this time.
Some videos are working fine, but a lot don't (e.g. https://www.youtube.com/watch?v=SYiNUkHiiL4).
After some more testing I found out, that every video seems to work now when I am not logged in.
But this can't be the final solution.
Here is the same issue described by someone else, but no answer yet:
https://github.com/jdf76/plugin.video.yo...issues/870
mklopez @
glenze @
samsonluk
Need a complete
debug log (wiki)
Tulon
Thanks for the heads up, you can keep your eye on
https://github.com/anxdpanic/plugin.vide...e/issues/6
sam.roscoe
This has been reported ~3-4 times, and I can't reproduce. No one has provided a complete
debug log (wiki) (that doesn't have banned add-ons), so I'm unable to see what you all have in common to help me reproduce.
Let me know if you're comfortable with installing a custom zip and providing a generated text file and some information, and I'll put something together.
Tulon please see below
sam.roscoe If possible please confirm if the beta below fixes your issue, if not please follow up with a complete
debug log (wiki)
I've updated post
#2 and the
repositories with 6.8.5~beta1
~beta1
[fix] notifications for some languages on Kodi 19
[fix] searching for some languages
[fix] loading on some versions of python 3
[fix] some videos failing to play with an Invalid URL exception
[upd] use xbmcvfs.translatePath if available, clean up for Kodi 19
