Hi, I just updated from Leia to Nexus. Do I need new YouTube API keys on Nexus ? I can’t get the addon to accept the api keys I used on Leia. I always get the error message "401 login exception invalid client type" after typing in the first code from Google.com/device .
cheers
phyrros
Hello, will MPEG-DASH enabled with Youtube work properly again?
I've not been able to sign in for ages now, I always get this error
error 401 invalid_client (invalid client type)
I've tried new keys but still cant log in. Anyone got any ideas ?
Is there a guide anywhere ? I followed a guide today as I thought I'd made an earlier set wrong but maybe thst guide had something wrong, it was a firestick guide for kodi so I thought it may work
Cheers
jepsizofye Cheers.
I did googke it and it brought ip a post with a dead link to an answer. I'lltry the guide tomorrow
Turns out that the instructional video in the api key creation part of the guide has been removed so the guide isnt very guidey
you could do a search on youtube and likely find a few (in your browser of course), i wont link any here because most of them mention pirate crap
I'vr reset yoitube to defaults so there are o api keys in and tried to sign in. I still get the error
So it doesnt seem to be key related. Anyone have any ideas ?
I've run into a big issue with YouTube on my systems, using 6.8.24 off the Kodi repo.
Last night one of my devices login expired, easy, put in a new one... And now I only had access to two of the channels I sub. All the other channels are seemingly invisible.
My other clients seemed ineffected but they're sitting on long lasting logins.
However, if I sign out on any of them and simply sign back in, that problem then occurs in them as well. It's as if new logins can no longer access the full list of subscriptions.
Uhh... Ideas?
anxdpanic
please, it is possible with next update to set as standard for folder "Saved Playlists" in settings.xml
for this match ->
https://imgur.com/a/elDOI4X
<setting help="" id="youtube.folder.saved.playlists.show" label="30611" type="boolean">
<level>0</level>
<default>false</default>
<dependencies>
<dependency type="visible">
<condition name="InfoBool" on="property">true</condition>
</dependency>
</dependencies>
<control type="toggle"/>
Thank you
(2023-03-17, 05:21)sus67 Wrote: [ -> ] (2023-03-06, 14:59)sus67 Wrote: [ -> ]@anxdpanic
since today this issue: "The following content is not available in this app"
https://paste.kodi.tv/azubaqixud.kodi
Thank you
SOLVED
with Channel migrated to Brand Account
YouTube Help
Hello,
How did it solve the issue ?
If you create another normal Google account and use it to access youtube, do you run into the same error ?
(2023-03-17, 11:56)edsic Wrote: [ -> ]Hello,
Nobe, same Google account and API like before. At first take a look to YT tutorials "create YouTube Brand account".
(2023-03-17, 16:14)sus67 Wrote: [ -> ] (2023-03-17, 11:56)edsic Wrote: [ -> ]Hello,
Can you explain what Brand accounts have to do with the "The following content is not available in this app" error ?
(2023-03-17, 18:43)edsic Wrote: [ -> ]Can you explain what Brand accounts have to do with the "The following content is not available in this app" error ?
I can't explain it, but it works. Since then no more message "The following content is not available in this app".
