I understood that the youtube plugin iis no longer working in regards to accessing personal settings. Is that correct?
But what I also experience is that some Videos simply do not play.
https://pastebin.com/wpXYLjGN
(2020-11-28, 18:36)anxdpanic Wrote: [ -> ]@Skeeve
Enable Settings - MPEG-DASH - Use MPEG-DASH and Settings - MPEG-DASH - Use for videos
Sounds like the solution. However, I cannot change anything there. It's telling me something about a proxy and to look for HTTP Server.
Hi everybody
I create a fix for empty "my subscriptions". It's using Youtube RSS feed to get latest videos from your subscriptions. I tested with 50 subscribers and it needs about 45 seconds to get results, it's not the fastest thing but it works
I also implemented cache so new videos are only get pulled once every hour.
Here is the link:
https://drive.google.com/file/d/1AB_bgcs...sp=sharing
You can install from zip inside Kodis Add-on section, or you can just simply overwrite files inside your kodi user files on your filesystem.
Enjoy
Thank you PureHemp
do we need to put any api details in before installing or just go ahead and install?
(2020-11-28, 23:19)graham23s Wrote: [ -> ]Thank you PureHemp
Just install it. It's the same as official add-on. I only modified script for retrieving "my subscriptions" videos.
(2020-11-28, 22:48)PureHemp Wrote: [ -> ]Hi everybody
Here is the link:
Enjoy
It worked for me. Thanks.
Worked great thank you mate
Regards
Graham
Thank You PureHemp. Besides taking about 5 seconds to open "My Subscriptions", it works perfectly. I look forward to using this everyday.
Just wanted to say thanks for the fix.
My god..
I just registered to say thank you to Purehemp for this fix.. Its been driving me nuts the last few days and i was afraid i was destined to use Chromium on the Pi for Youtube from now on... Granted it probably takes about 2 minutes to refresh my 200+ subscriptions but i can live with that! Thank you again!
Jomjom79
