Full Version: YouTube
Happened to me today, can confirm the update works, quick fix!
The icon is not great tho but...
Thank you!
(2021-08-27, 02:55)Petes Wrote: [ -> ]Happened to me today, can confirm the update works, quick fix!
Thank you!
I downloaded the .zip update and put it on a USB and tried to install it. There was an error that said it was the wrong structure. How else can I install it?
6.8.16 on Matrix suddenly works fine. May someone explain, what happened?
@anxdpanic the unofficial repo it's not works on kodi 19 ??
I have installed the both unofficial repo.......... apparently there's no ways to install the current 6.8.17+matrix.1 unofficial Sad I can only update from official kodi repo.
the official Kodi-repo has the new (working) version 6.8.17 for Matrix
just do a "search for updates"
(2021-08-27, 12:33)Solo0815 Wrote: [ -> ]the official Kodi-repo has the new (working) version 6.8.17 for Matrix
No update for Leia that fix ratebypass so far.
EDIT: available now and works Smile
if it's an answer for me.... i have already installed it from official kodi but usually i use the unofficial version......... and it's not been released on testing or unofficial repo ?
*EDIT*
And yes....... just a confirmation....... the official matrix repo here:
https://panicked.xyz/repositories/matrix/ (i have need to retrive the repo xml....)
It's not been updated to 6.8.17....... but the zip it's been released on github. The panicked repo it's not used the same zip posted on github ??
I don't have idea........
Playlists no longer working on newest update. Fyi.
Playlists work fine for me on 6.8.17+matrix.1 (Unofficial)
(2021-08-27, 20:47)kurai Wrote: [ -> ]Playlists work fine for me on 6.8.17+matrix.1 (Unofficial)
I'm on legit the same version......so no clue why it's not working
Standard advice time Smile
Turn on debug loglevel and submit full (not edited) log via whatever the current prefered pastbin type site is.
youtube comments (context menu) have also stopped working.
using the latest 6.8.17_alpha1 on Leia 18.9 (ubuntu 20.04 LTS)
No issues if the video has no comments
otherwise this is the error.
(2021-08-27, 20:53)kurai Wrote: [ -> ]Standard advice time Smile
Where did u get the unofficial version from?
(2021-08-28, 18:16)djgrind Wrote: [ -> ]Where did u get the unofficial version from?
From the Source link in the first post.
i.e. https://github.com/anxdpanic/plugin.vide...e/releases
v6.8.17 release, 3rd link in Assets sub-heading
(2021-08-28, 18:38)kurai Wrote: [ -> ]
Ok yes. Definitely same version. Still Playlist from channels don't work.
Oh well. I'll just wait for another update.
Thanks for trying to help tho.
