(2021-10-19, 17:13)angelitto Wrote: [ -> ]@Grarea, you need to figure it out. It's a bit different to make an API key, because google changed a bit the procedure, but if you insist, you will succed eventually. Or search for a newer tutorial on youtube.
Just to say thanks to all for being here.
I eventually managed to get in.
Next to read up as to what this alpha stuff is all about.
Alpha 6 containing a fix for Age Gate Videos has gone up on GitHub and is also available from the Test Repo:
https://github.com/anxdpanic/plugin.vide.../6.x.x-dev
6.x.x-dev Pre-release
@github-actions github-actions released this 2 hours ago
[fix] Fix to_str |contrib: RNavega|
[fix] Fix playback buffering |contrib: RNavega|
[lang] translation updates from Weblate
Hope this helps
(2021-10-19, 16:35)Doktor-X Wrote: [ -> ]can anyone try play https://youtu.be/pZ2bLSIcOms (age restricted video) using alpha 4. Im using s912 box running coreelec kodi 19 and its only playing with alpha 1
Thanks for reporting this on GitHub. This issue was immediately fixed and the above Age Restricted Video now plays in Alpha 6
(2021-10-20, 08:42)jmh2002 Wrote: [ -> ] (2021-10-10, 23:35)jmh2002 Wrote: [ -> ]Naturally you should choose the Matrix Repos for Kodi v19 Matrix installations, and Not the Matrix Repos for older setups.
To confirm, there is no functional difference as far as playback of videos is concerned between the Official and UnOfficial versions.
The only difference is that the UnOfficial version includes an option to set the Kodi 'View Type' automatically for your skin (eg: List, Media Info, Thumbnail, etc).
Hope this helps
Thank you. It works perfectly. One of the best add on ever.
6.8.18.alpha4 completely cured the severe buffering issue on my ancient Jarvis (Alienware) box - thank you from the bottom of my heart!
Live streams of any sort refuse to play, though. Log shows dozens of failed Cookie fetches right after starting Demux for a live stream, followed by an exit. I don't see anything like this in the log when playing normal, non-live streams - normal procedures follow the Demux launch.
Anyone else seeing 18.alpha4 refusing live streams, or am I special?
(2021-10-21, 04:43)Parker Evans Wrote: [ -> ]6.8.18.alpha4 completely cured the severe buffering issue on my ancient Jarvis (Alienware) box - thank you from the bottom of my heart!
I should mention that 6.8.17 still plays live streams just fine under Jarvis - it was just non-live streams that were suffering the atomic buffer wedgie.
(2021-10-21, 04:43)Parker Evans Wrote: [ -> ]Anyone else seeing 18.alpha4 refusing live streams, or am I special?
I'm on Alpha 6 now but I just did a quick test of France24 and Al Jazeera live news streams and they play without any issues.
I have Settings > MPEG-DASH > Use For Live Streams > set to Enabled
EDIT: I now see that you have Kodi Jarvis? That is a
really old version (version 16?), I'm not sure if that is contributing to your problem.
Post your issue on GitHub here please:
https://github.com/anxdpanic/plugin.vide...ube/issues
(2021-10-21, 05:02)jmh2002 Wrote: [ -> ] (2021-10-21, 04:43)Parker Evans Wrote: [ -> ]Anyone else seeing 18.alpha4 refusing live streams, or am I special?
EDIT: I now see that you have Kodi Jarvis? That is a really old version (version 16?), I'm not sure if that is contributing to your problem.
Post your issue on GitHub here please: https://github.com/anxdpanic/plugin.vide...ube/issues
Note that the previous official release (.17) doesn't have problems with live streams, and MPEG-DASH is not available under Jarvis.
(2021-10-21, 05:16)Parker Evans Wrote: [ -> ]Note that the previous official release (.17) doesn't have problems with live streams, and MPEG-DASH is not available under Jarvis.
Noted
Post your issue on GitHub here please and be sure to detail that you are running Jarvis:
I created an account on GitHub, and posted a bug. Noticed when running both .17 and 18.alpha4 that invalid cookies showed up in both logs, so that was a red herring.
jmh2002, github problem closed since its fixed, thanks to dev until next time
6.8.18.alpha6+matrix working perfectly!!! Many thanks to dev.
with 6.8.18.alpha6+matrix YouTube working perfectly! no buffering ... thanx!
I am not sure what I may be doing wrong here but how can I get YT videos to playback in 1080p? It seems all I can do is playback in 720p. I have it set to 1080pLive/720p.
Thanks in advance.
Shedrock
