(2021-10-17, 23:02)jmh2002 Wrote: [ -> ] (2021-10-17, 22:59)nycman Wrote: [ -> ]jmh2002 are these the ones to try?
See my post just above. I took the time to give you the exact details.
You need this version for Matrix: plugin.video.youtube-6.8.18.alpha3+matrix.1.zip
PS: per my post here with a copy of the release notes you will need to sign in again - twice:
https://forum.kodi.tv/showthread.php?tid...pid3065230
Hi, new to this forum and I would like to give a huge thanks for your efforts which solved this issue.
Up until about 3 - 4 weeks ago my rPI4 Kodi/ Youtube addon was performing perfectly. After that, videos seemed to buffer more and more, then the last week it was unusable.
Thought it was the wi-fi from my boiler's thermostat clashing. Nope.
Tried updating the youtube addon, no luck.
Trawled forums suggesting cache needed emptying. Long winded procedure to download/install addon to do that, plus it nagged me to subscribe to VPN so I uninstalled.
Increased memory buffer. No luck. Videos now took longer to start.
Thought Kodi may have corrupted so reinstalled it, no luck.
Tried another OS (OSMC) but that doesn't support YouTube (to my knowledge)
Downgraded Kodi to v9.2, HDMI connection constantly dropped.
Considered buying new microSD card in case existing one was wearing out. Didn't bother in the end.
Reinstalled Kodi to 10.0, and activated debug logging. Showed errors indicating source not available. Warning box indicated source too slow.
Set maximum channel number on my router, no luck
I can watch youtube on my phone without any issues so can't be wi-fi transfer rate.
Moved router from desk to floor upstairs (away from electrical equipment). No change
Moved Pi upstairs so in same room as router, and used ethernet connection. No change.
Found this forum, and despite having not used Alpha or beta software before, gave it a shot. Nothing to lose doing so. URL reported 'could not connect' error so using another PC I downloaded zip file, copied it straight to Pi's sd card and installed addon.
Copied youtube API keys from backed up json file.
Started youtube addon again and played back video. Virtually no buffering at start. Completely smooth playback. Success!
It's been a ball ache trying to find the issue when it was the previous YouTube addon.
Huge thanks again for working on this latest version. Without tempting fate, let's see how long this one lasts before Youtube put their foot in it once again. Hopefully a long time.
Best regards
