2020-09-09, 09:48
The TVmaze Scobbler/Tracker addon has finally been released to the Kodi addon repo.
What this addon does:
Performs an initial sync between Kodi and TVmaze for the episodes you've watched.
If you add an episode to the Kodi library it marks it as "acquired" on TVmaze.
If you watch an episode in Kodi it marks it as "watched" in TVmaze.
If you mark an episode as watched in TVmaze it marks it as watched in Kodi
To use this addon you need to have an account on TVmaze. A free account is enough. The addon can be installed from Kodi Addon Manager: Install from repository > Program addons > TVmaze Scobbler/Tracker.
After installation you need to authorize the addon. Go to Addons > Program addons, lauch TVmaze Scobbler/Tracker and select "Auhorize the addon" in the addon menu. After that you can do initial sync of all you TV shows with TVmaze.
Source code on GitHub: https://github.com/romanvm/kodi.tvmaze.scrobbler
Please post your bug reports and feature request as issues in the GitHub project. For bug reports Kodi debug logĀ (not a regular one!) is mandatory.
