Guys its Crazy; when I tried to play any video neither it played nor it opened. The Video should open atleast. If u have experenced this before then please help me to fix it.
Here's the screen-recording-
https://streamable.com/gorpw1
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
Did you read the
forum rules (wiki) when you signed up here, particularly the
piracy policy (wiki) and the bit about
banned addons (wiki)?
You will have to remove the stuff in
orange in your log and submit a new, clean version before we can offer you any support.
The forum moderators have determined that
banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
(2020-09-14, 22:14)Karellen Wrote: [ -> ]The forum moderators have determined that banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
Sry sir for not reading the rule, Here's the new log-
https://paste.kodi.tv/ojugavurum.kodi
(2020-09-15, 12:30)xavierxross Wrote: [ -> ]Sry sir for not reading the rule, Here's the new log-
I still see orange add-on items... Our patience is not indefinite. Either uninstall/remove the orange items, or start with a new setup.
