Full Version: Game controller works in kodi UI but not in P-UAE
Hi all.
I have a strange problem.
I was connect xbox one controller to the Intel Nuc (Kodi LibreElec).
The controller works ferfectly in the kodi UI (keys, cursors...)
But if i launch a game the controller do not work Sad
Any sugestions ?
Platform: Intel NUC
Kodi: 18.8.0
P-UAE: 2.6.1
Game: Turrican II
Please post a debug log. In this log, I can usually tell why input is not working.
(2020-10-05, 08:23)garbear Wrote: [ -> ]Please post a debug log. In this log, I can usually tell why input is not working.
Hi.
Thank you for your answer.
kodi.log: https://paste.kodi.tv/xanoxuzibo.kodi
input.log: https://paste.kodi.tv/oxevidiyov
(2020-10-15, 19:06)zmylna Wrote: [ -> ]
Hi.
Anyone ?
Hi zmylna,
I think I see the problem. The input system we use to connect every physical controller to every emulated controller needs to know about the UAE core. In the log, I see:
Libretro input bindings:
Port: 0, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_A, Description: A / 2nd fire / Blue
Port: 0, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_B, Description: B / Fire / Red
Port: 0, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_X, Description: X / Yellow
Port: 0, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_Y, Description: Y / Green
Port: 0, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_SELECT, Description: Select
Port: 0, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_START, Description: Start / Play
Port: 0, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_RIGHT, Description: Right
Port: 0, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_LEFT, Description: Left
Port: 0, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_UP, Description: Up
Port: 0, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_DOWN, Description: Down
Port: 0, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_R, Description: R / Forward
Port: 0, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_L, Description: L / Rewind
Port: 0, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_R2, Description: R2
Port: 0, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_L2, Description: L2
Port: 0, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_R3, Description: R3
Port: 0, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_L3, Description: L3
Port: 0, Device: RETRO_DEVICE_ANALOG, Feature: RETRO_DEVICE_INDEX_ANALOG_LEFT, Component: RETRO_DEVICE_ID_ANALOG_X, Description: Left Analog X
Port: 0, Device: RETRO_DEVICE_ANALOG, Feature: RETRO_DEVICE_INDEX_ANALOG_LEFT, Component: RETRO_DEVICE_ID_ANALOG_Y, Description: Left Analog Y
Port: 0, Device: RETRO_DEVICE_ANALOG, Feature: RETRO_DEVICE_INDEX_ANALOG_RIGHT, Component: RETRO_DEVICE_ID_ANALOG_X, Description: Right Analog X
Port: 0, Device: RETRO_DEVICE_ANALOG, Feature: RETRO_DEVICE_INDEX_ANALOG_RIGHT, Component: RETRO_DEVICE_ID_ANALOG_Y, Description: Right Analog Y
Port: 1, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_A, Description: A / 2nd fire / Blue
Port: 1, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_B, Description: B / Fire / Red
Port: 1, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_X, Description: X / Yellow
Port: 1, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_Y, Description: Y / Green
Port: 1, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_SELECT, Description: Select
Port: 1, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_START, Description: Start / Play
Port: 1, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_RIGHT, Description: Right
Port: 1, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_LEFT, Description: Left
Port: 1, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_UP, Description: Up
Port: 1, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_DOWN, Description: Down
Port: 1, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_R, Description: R / Forward
Port: 1, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_L, Description: L / Rewind
Port: 1, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_R2, Description: R2
Port: 1, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_L2, Description: L2
Port: 1, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_R3, Description: R3
Port: 1, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_L3, Description: L3
Port: 1, Device: RETRO_DEVICE_ANALOG, Feature: RETRO_DEVICE_INDEX_ANALOG_LEFT, Component: RETRO_DEVICE_ID_ANALOG_X, Description: Left Analog X
Port: 1, Device: RETRO_DEVICE_ANALOG, Feature: RETRO_DEVICE_INDEX_ANALOG_LEFT, Component: RETRO_DEVICE_ID_ANALOG_Y, Description: Left Analog Y
Port: 1, Device: RETRO_DEVICE_ANALOG, Feature: RETRO_DEVICE_INDEX_ANALOG_RIGHT, Component: RETRO_DEVICE_ID_ANALOG_X, Description: Right Analog X
Port: 1, Device: RETRO_DEVICE_ANALOG, Feature: RETRO_DEVICE_INDEX_ANALOG_RIGHT, Component: RETRO_DEVICE_ID_ANALOG_Y, Description: Right Analog Y
Port: 2, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_A, Description: A / 2nd fire / Blue
Port: 2, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_B, Description: B / Fire / Red
Port: 2, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_X, Description: X / Yellow
Port: 2, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_Y, Description: Y / Green
Port: 2, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_SELECT, Description: Select
Port: 2, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_START, Description: Start / Play
Port: 2, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_RIGHT, Description: Right
Port: 2, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_LEFT, Description: Left
Port: 2, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_UP, Description: Up
Port: 2, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_DOWN, Description: Down
Port: 2, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_R, Description: R / Forward
Port: 2, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_L, Description: L / Rewind
Port: 2, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_R2, Description: R2
Port: 2, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_L2, Description: L2
Port: 2, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_R3, Description: R3
Port: 2, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_L3, Description: L3
Port: 2, Device: RETRO_DEVICE_ANALOG, Feature: RETRO_DEVICE_INDEX_ANALOG_LEFT, Component: RETRO_DEVICE_ID_ANALOG_X, Description: Left Analog X
Port: 2, Device: RETRO_DEVICE_ANALOG, Feature: RETRO_DEVICE_INDEX_ANALOG_LEFT, Component: RETRO_DEVICE_ID_ANALOG_Y, Description: Left Analog Y
Port: 2, Device: RETRO_DEVICE_ANALOG, Feature: RETRO_DEVICE_INDEX_ANALOG_RIGHT, Component: RETRO_DEVICE_ID_ANALOG_X, Description: Right Analog X
Port: 2, Device: RETRO_DEVICE_ANALOG, Feature: RETRO_DEVICE_INDEX_ANALOG_RIGHT, Component: RETRO_DEVICE_ID_ANALOG_Y, Description: Right Analog Y
Port: 3, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_A, Description: A / 2nd fire / Blue
Port: 3, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_B, Description: B / Fire / Red
Port: 3, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_X, Description: X / Yellow
Port: 3, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_Y, Description: Y / Green
Port: 3, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_SELECT, Description: Select
Port: 3, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_START, Description: Start / Play
Port: 3, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_RIGHT, Description: Right
Port: 3, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_LEFT, Description: Left
Port: 3, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_UP, Description: Up
Port: 3, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_DOWN, Description: Down
Port: 3, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_R, Description: R / Forward
Port: 3, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_L, Description: L / Rewind
Port: 3, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_R2, Description: R2
Port: 3, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_L2, Description: L2
Port: 3, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_R3, Description: R3
Port: 3, Device: RETRO_DEVICE_JOYPAD, Feature: RETRO_DEVICE_ID_JOYPAD_L3, Description: L3
Port: 3, Device: RETRO_DEVICE_ANALOG, Feature: RETRO_DEVICE_INDEX_ANALOG_LEFT, Component: RETRO_DEVICE_ID_ANALOG_X, Description: Left Analog X
Port: 3, Device: RETRO_DEVICE_ANALOG, Feature: RETRO_DEVICE_INDEX_ANALOG_LEFT, Component: RETRO_DEVICE_ID_ANALOG_Y, Description: Left Analog Y
Port: 3, Device: RETRO_DEVICE_ANALOG, Feature: RETRO_DEVICE_INDEX_ANALOG_RIGHT, Component: RETRO_DEVICE_ID_ANALOG_X, Description: Right Analog X
Port: 3, Device: RETRO_DEVICE_ANALOG, Feature: RETRO_DEVICE_INDEX_ANALOG_RIGHT, Component: RETRO_DEVICE_ID_ANALOG_Y, Description: Right Analog Y
Our input system uses two files to describe this configuration: topology.xml and buttonmap.xml. It looks like these files need to be updated to the core's new input configuration.]. It looks like these files need to be updated to the core's new input configuration.
I don't have time to update the XML now, but if you do, I can assist.[/url]
(2021-01-12, 07:18)garbear Wrote: [ -> ]Hi zmylna,
Understand but i do not have necessary knowledge to do this Sad
(2021-02-24, 17:10)zmylna Wrote: [ -> ]
ok, i do some tests.
Looks like P-UAE addon do not see the controller.
If i press ctrl on the keyboard i see in the log something like this:
DEBUG: AddOnLog: Commodore - Amiga (P-UAE): Controller "game.controller.keyboard" key "leftctrl" (RETROK_LCTRL) modifier 0x00000002: down
If i press "a" on the xbox controller i see this:
DEBUG: BUTTON [ 0 ] on "Xbox Wireless Controller" pressed
DEBUG: FEATURE [ a ] on game.controller.default pressed (ignored)
DEBUG: FEATURE [ a ] on game.controller.default pressed (handled)
DEBUG: BUTTON [ 0 ] on "Xbox Wireless Controller" released
DEBUG: FEATURE [ a ] on game.controller.default released
There is no "AddOnLog: Commodore - Amiga (P-UAE)".
The add-on does not capture events from the controller.
---edit---
I think that this is the problem:
2021-02-25 22:26:30.253 T:140463586158336   ERROR: AddOnLog: Joystick Support: Device "Sony Interactive Entertainment Wireless Controller": can't find <controller> tag
or this:
2021-03-02 16:25:52.758 T:140180731189376   DEBUG: AddOnLog: Joystick Support: Loaded device "Keyboard" with 1 controller profiles and 139 total features
2021-03-02 16:25:52.761 T:140180731189376   DEBUG: AddOnLog: Joystick Support: Loaded device "Mouse" with 1 controller profiles and 1 total features
2021-03-02 16:25:52.762 T:140180731189376   DEBUG: AddOnLog: Joystick Support: Loaded device "Mouse" with 1 controller profiles and 10 total features
Two mouses ??
@garbear , can you confirm my assumptions ?
