Full Version: pvr.stalker 3.4.10 preview channel select to disable jump to fullscreen
stalker client 3.4.10 on Kodi 18.8
Each time I click select channel on left preview screen column, it would close a preview page and open the channel in full screen. On older version stalker client 1.0.12  for kodi 16.1, it stays on preview while browsing different channel, unless I click on that channel or click on preview screen then it would switch to full screen.
Is there anyway to change this new behavior to the old way as it should be for browsing preview purpose?
Is it required a lot of work that must be request as an issue to fix?
Found a solution, System settings > PVR & Live TV > Playback > uncheck - Switch to full screen [default is checked].
Mod, please mark as solved. Thanks
