My remote :
X10 Medion RF Remote Control (P/N 20017670)
Application I made for this remote.
Successfully tested on XP Pro Sp2
Must work on Vista (need feedback)
What is supported :
- Start / Shutdown (Quit) XBMC PC
- Play, Stop, Pause
- Left, Right, Up, Down
- Volume Up / Down
- Jump Forward / Jump Back
- FF / RW
- Shutdown PC
- Screenshots (New)
- Program minimized to systray (New)
- Successfully tested on XP Pro SP2
Be sure Windows Media Center is not running (Must be killed in Task Manager)!!
You don't need to change anything in Keymap.xml
Use setup to install the program & enjoy using your X10 Medion Remote.
Download here
Gimme some feedback ;-)
Dav.
hey, i'd like to give it a try, cause girder won't give any commands to xbmc...
unfortunately the downloadlink isn't working.
hope you can fix it; controlling with keyboard isn't much fun.
thanks in advance...
This version was removed (old one)
Try this one :
1) Install VB6 DLL's :
VB6 Library's
2) Download last current version :
X10-BMC.exe (v0.0.8)
NB : NOT working with Atlantis (for the moment)
Please give some feedback.
Thank you,
Dav.
hi, thanks for reply.
i think, i posted a bit to rash. after some trouble i got the RC working with IRSS, which does its job very well. so, thanks anyway
No probs
Anyway I just realised that X10-BMC must work with ATi Wonder remotes.
Maybe users with ATi Wonder remotes may confirm this ?
Dav.
Hi Dav.,
any plans to make this work with Atlantis or are you waiting for the final?
cheers,
-=Bender=-
The version i'm using work perfectly with Atlantis Beta 1 & 2.
I can post the last version this week-end if you want it.
Cya,
Dav.
Hi Dav.,
that would be cool.
I´d like to try it.
Have had this remote control lying around here for some years now and was about to throw it out. So eventually it will live a litte longer then.
No hurry though.
Thanks,
-=Bender=-
Hi all,
Thanks to Melloware for this feedback.
Here is the last version (v0.0.10)of
X10BMC.
If it's the first time you install it, don't forget to install the
VB6 DLL's
Self mapping keys is not ready in this version because not enough time &
It's really hard to make a mapping with only one remote model
What's new :
- Work with XP & Vista
- Work with Atlantis Beta 1 & 2
- For Vista Ultimate users, Windows Media Center is neutralized.
- Start & Shutdown XBMC with the power button
- Run in Systray
With or without problem's, please give some feedback. Thanks.
Enjoy !
Dav.
Wanted to test this with my 'vista-only' AIM rc,
vb6 dll's download.. after downloading, exe fails to run, says possible transfer error.
Sorry, I have the same problem.
Try this one (Unzip & Install)
VB6 Dll's
Cya,
Dav.
No feedback, No comment, No one to reply ?
Guy's, if you want new update for this program, I need your help.
Without this, I can't adapt or make new version's !
Thank's,
Dav.
Hi Dav!
Really nice work you're doing.
I have tried it for a couple of days now and it works pretty good. I have the old All in Wonder remote.
I use your program together with the program that came with the remote to program the programmable buttons (A,B,C,D,E and F) and it works great.
The only thing that i really miss is two buttons for browsing through the music playlist while playing, one forward and one backwords. I think its the buttons ',' and '.' on the keyboard in xbmc.
Keep up the good work!
Hi sahlen,
Thanks for the report.
I will try to make an update for this asap.
KR,
Dav.
sahlen Wrote:The only thing that i really miss is two buttons for
Here is the last version (v0.0.10) of
X10-BMC. (minor update for sahlen request only)
New users, don't forget to install the
VB6 DLL's
- Running under XP & Vista
- XBMC Atlantis Final, Atlantis beta 1 & Atlantis beta 2 supported
KR,
Dav.
