2020-09-21, 10:50
I'm still on same machine and have setup a Centos distribution.
Firstly some weeks ago, as Centos 8.2 have no repo for Kodi except a subscription one, i had install kodi via Flatpak.
All is fine under Flatpak, including Vdpau Bob deinterlace.
As Flatpak don't update the application often (still at 18.7 version ...), i have decided to compile Kodi 19 + all plugins from source this week end.
Compilation is done for Kodi Matrix, a bug for plugins...
I have found the solution there : https://github.com/xbmc/xbmc/issues/17493 , but perhaps on wrong place ?
In fact, kodi-x11 and kodi-xrand binarys are located in /usr/local/lib64/kodi directory and plugings in usr/local/lib/kodi/addons , so the application didn't find the plugins for install. After copy the plugin directory to the lib64 one, plugins will install.
