Got any recommendation to use with XBMC? Which wireless keyboard/mouse?
For remote i am going to be getting Microsoft MCE remote (~$50). is this supported? If not which universal remote is supported?
MCE is well supported, just choose it when installing lirc (Will be a wizard were you choose mceusb2).
For mouse you can consider the wiiremote, good mouse in HTPC usage
I use the MCE Keyboard and based on my experience the drivers for LIRC are quite unfinished. The media keys and the mouse is working as expected but the repeat rate when typing is very fast. Unfortunately the developer of the driver seems to have lost interest in the project. I'm also growing tired of the IR-technology. Does anyone have any experience with bluetooth media keyboards and linux? PlugandPlay or are you required to build kernel drivers similar to the MCE Keyboard drivers?
Topfs2 Wrote:MCE is well supported, just choose it when installing lirc (Will be a wizard were you choose mceusb2).
I have a Wii and i've already ordered a cheap bluetooth usb but how will the wiiremote be used as a mouse?
ekurin Wrote:I use the MCE Keyboard and based on my experience the drivers for LIRC are quite unfinished. The media keys and the mouse is working as expected but the repeat rate when typing is very fast. ...
ekurin, I found this thread
http://ubuntuforums.org/showthread.php?t=592057&page=2
that mentions this work-around:
Hope it helps...
I have this remote also and I have had problems getting it to work with lirc. Ive followed the instructions and it just wont work right for me. Anyone wanna help me out
mr.b Wrote:@ekurin, I found this thread
Hope it helps...
Thanks for trying to help out mr.b. I've tried to disable the auto-repeat and it works everywhere except in XBMC. However I disabled the auto-repeat via the gnome-settings menu, don't know if it has the same effect as xset ( I suppose it does)
And MPauley73 visit the link mr.b posted and follow the guide on the first thread page. That's how I got my keyboard working in the first place.
Guess I was just having a "dense day"... the keyboard is working, but in xbmc whatever the last key pressed is, well just keep on going and going....
shagworthy_uk Wrote:but i will be buying this soon:
http://www.logitech.com/index.cfm/keyboa...8&cl=us,en
Just purchased one of these today, I have beeen looking into for sometime- one word AWESOME!
running XBMC Linux Gutsy, keyboard was recognized right away, needed to patch for touchpad/mouse (just google).
The wireless keyboard is small like a blackberry very easy to thumb-type on.
The touchpad/mouse is dual purpose, simply switch from mouse to 'directional buttons' and you have a complete XBMC remote control for navigating through the menus.
If all that weren't enough, the device looks awesome and compliments HTPC setup and has a backlight for the keypad so that you don't have to turn up the lights when you are watching a movie or TV show with your HT mood lighting.
so that replaces both a keyboard and a mouse?
davidw89 Wrote:so that replaces both a keyboard and a mouse?
Yes, Keyboard, Mouse, and wireless XBOX1 controller that I was still using.
touchpad mouse takes a little getting used to, but now I can power off XBMC, use Gutsy (ie; firefox, terminal, open office, etc.), and then reopen XBMC all from one remote.
There is a manual switch right beside the touchpad that lets you switch from mouse to arrow pad.
Ok button is on the left side of the keyboard in a comfortable location.
Also last night I tried the media buttons across the top of the keyboard and they all work as well in XBMC (ie; play/pause, stop, advance, etc.)
and my wife really likes the diNovo mini interface as well (finds it more comfortable than wired keyboard and the XBOX1 controller)
cheers
davidw89 Wrote:I have a Wii and i've already ordered a cheap bluetooth usb but how will the wiiremote be used as a mouse?
Basicly, if you use the PPA then you do
sudo apt-get install xbmc-eventclients-wiiremote
Then you need to run that program on boot. You need to press 1+2 on the wiiRemote to connect and you need to map the keymap.xml
I will hopefully add a good keymap version for the wiiremote to svn at some point but for now you need to do it yourself >)
Anyway, heres some read about the WiiRemote eventclient
http://wiki.xbmc.org/?title=EventServer
and
http://wiki.xbmc.org/?title=EventServer#WiiRemote
Topfs2 Wrote:Basicly, if you use the PPA then you do
Anyway, heres some read about the WiiRemote eventclient http://wiki.xbmc.org/?title=EventServer
and http://wiki.xbmc.org/?title=EventServer#WiiRemote
Probably a VERY stupid question here but just so I can understand if I am interpreting this correctly... Can this Wiiremote be used for XBMC even if you DON'T have a Wii? This would be awesome and I would get one if this is possible. If someone gets a good laugh at this question it's worth the gains that could be had if it works like I think
