2020-09-27, 18:06
Hello ladies and gentlemen,
I am trying to set-up Kodi to access a remote hard disk on a 32bit Linux Mint 18.1 Cinnamon computer that uses Samba version 4.3.11-Ubuntu.
Kodi 18.7 Leia runs on a 4Gb Raspberry Pi 4, on top of LibreELEC (official): 9.2.3, both installed via NOOBS and running fine using local USB storage devices.
I have been at this for a few evenings and afternoons now, without success. Several articles, forums and blogs later and I'm still stuck getting this to work.
Please note the output of the smbtree command on LibreELEC, in bold red font below. (This was why I tried to force a protocol below).
Any logs or files you might want to see, just let me know and I'll do what I can.
Thanks for your time and help.
Rembrandt.
PS Apologies for the layout; I am typing this on a 10inch screen, crappy touch pad and no mouse. Aaargh.
I've set-up / done the following:
-I can ping each machine from the other both by IP address and by hostname.
-Linux Mint:
-useradd libreelec
-smbpasswd -a libreelec
-chmod 777 the path to be shared with Kodi
-Added netbios name of less than 15 chars to /etc/samba/smb.conf
-Shortened and removed spaces from path of shared folder.
-ufw disabled for now
-Added to bottom of /etc/samba/smb.conf:
[share-1]
path = /media/png/Disk1/
valid users = libreelec
read list = libreelec
write list = libreelec
browsable = no
-Tried forcing protocols to SMB3 in /etc/samba/smb.conf, without success
server min protocol = SMB3
server max protocol = SMB3
-systemctl restart smbd
-samba-tool testparm:
Press enter to see a dump of your service definitions
# Global parameters
[global]
workgroup = WORKGROUP
netbios name = FRIDGE
server string = %h server (Samba, Ubuntu)
map to guest = Bad User
obey pam restrictions = Yes
passdb backend = tdbsam
pam password change = Yes
passwd program = /usr/bin/passwd %u
passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
unix password sync = Yes
log file = /var/log/samba/log.%m
max log size = 1000
usershare allow guests = Yes
panic action = /usr/share/samba/panic-action %d
[printers]
comment = All Printers
path = /var/spool/samba
create mask = 0700
printable = Yes
browseable = No
[print$]
comment = Printer Drivers
path = /var/lib/samba/printers
[share-1]
browseable = No
-On LibreELEC:
(- samba-tool does not seem to be available)
-testparm:
rlimit_max: increasing rlimit_max (1024) to minimum Windows limit (16384)
Registered MSG_REQ_POOL_USAGE
Registered MSG_REQ_DMALLOC_MARK and LOG_CHANGED
Load smb config files from /run/samba/smb.conf
Processing section "[Update]"
Processing section "[Videos]"
Processing section "[Music]"
Processing section "[TV Shows]"
Processing section "[Recordings]"
Processing section "[Downloads]"
Processing section "[Pictures]"
Processing section "[Emulators]"
Processing section "[Configfiles]"
Processing section "[Userdata]"
Processing section "[Screenshots]"
Processing section "[Logfiles]"
Processing section "[Backup]"
Processing section "[Picons]"
Processing section "[TOSHIBA EXT]"
Processing section "[TOSHIBA EXT2]"
Processing section "[data]"
Processing section "[root]"
Loaded services file OK.
Server role: ROLE_STANDALONE
# Global parameters
[global]
deadtime = 30
enable core files = No
guest account = root
load printers = No
min receivefile size = 16384
name resolve order = host bcast
passdb backend = smbpasswd
printcap name = /dev/null
security = USER
server min protocol = SMB2
server string = LibreELEC
socket options = TCP_NODELAY IPTOS_LOWDELAY
username map = /run/samba/samba.map
fruit:model = Xserve
idmap config * : backend = tdb
aio read size = 16384
aio write size = 16384
allocation roundup size = 0
mangled names = no
smb encrypt = No
use sendfile = Yes
[Update]
path = /storage/.update
root preexec = mkdir -p /storage/.update
[Videos]
path = /storage/videos
root preexec = mkdir -p /storage/videos
[Music]
path = /storage/music
root preexec = mkdir -p /storage/music
[TV Shows]
path = /storage/tvshows
root preexec = mkdir -p /storage/tvshows
[Recordings]
path = /storage/recordings
root preexec = mkdir -p /storage/recordings
[Downloads]
path = /storage/downloads
root preexec = mkdir -p /storage/downloads
[Pictures]
path = /storage/pictures
root preexec = mkdir -p /storage/pictures
[Emulators]
path = /storage/emulators
root preexec = mkdir -p /storage/emulators
[Configfiles]
path = /storage/.config
root preexec = mkdir -p /storage/.config
[Userdata]
path = /storage/.kodi/userdata
root preexec = mkdir -p /storage/.kodi/userdata
[Screenshots]
path = /storage/screenshots
root preexec = mkdir -p /storage/screenshots
[Logfiles]
path = /storage/logfiles
root preexec = createlog
[Backup]
path = /storage/backup
root preexec = mkdir -p /storage/backup
[Picons]
path = /storage/picons
root preexec = mkdir -p /storage/picons/tvh /storage/picons/vdr
[data]
path = /media/data
[root]
path = /media/root
-smbtree:
WORKGROUP
\\LOCALHOST Samba Server Version 4.10.8
smbXcli_negprot_smb1_done: No compatible protocol selected by server.
\\LIBREELEC LibreELEC
\\FRIDGE HPM server (Samba, Ubuntu)
\\FRIDGE\IPC$ IPC Service (HPM server (Samba, Ubuntu))
\\FRIDGE\print$ Printer Drivers
\\COMPUTER
HOME
\\..... [ stuff about my router ]
-On Kodi:
Settings/Services/SMB client: (settings level Expert)
Workgroup WORKGROUP
WINS server 0.0.0.0
Min prot SMBv2 (both at SMBv3, and min prot at SMBv1 : no success)
Max prot SMBv3
Use legacy security off
Add network location:
After adding the network location on Kodi an error message comes straight up:
Error
Error 2: share not available
EDIT adding the network source regardless of availability, error message:
Remote share
Couldn't connect to network server
Rembrandt.
-Linux Mint:
-useradd libreelec
[share-1]
browsable = no
# Global parameters
[global]
max log size = 1000
[printers]
create mask = 0700
printable = Yes
browseable = No
[print$]
[share-1]
browseable = No
-On LibreELEC:
-testparm:
# Global parameters
[global]
deadtime = 30
load printers = No
security = USER
mangled names = no
smb encrypt = No
use sendfile = Yes
[Update]
[Videos]
[Music]
[TV Shows]
[Recordings]
[Downloads]
[Pictures]
[Emulators]
[Configfiles]
[Userdata]
[Screenshots]
[Logfiles]
[Backup]
[Picons]
[data]
path = /media/data
[root]
path = /media/root
-smbtree:
WORKGROUP
\\COMPUTER
HOME
-On Kodi:
Workgroup WORKGROUP
WINS server 0.0.0.0
Max prot SMBv3
Protocol Windows network (SMB)
Server name IP address (of Mint machine that I can ping)
-Browse
Shared folder /media/png/Disk1/ (also tried name of shared folder: share-1)
Port (greyed-out)
Username libreelec (as setup on Mint)
Password password (as setup for libreelec user, smbpasswd on Mint)
EDIT There is no /storage/.kodi/.smb/user.confServer name IP address (of Mint machine that I can ping)
-Browse
Port (greyed-out)
Error
Remote share
