Full Version: .strm files crashing...
Hello,
I have a file named "P3 - Rockster.strm" with this text:
"mms://wm-live.sr.se/SR-P3Rockster-High"
The original Xbox XBMC plays it without problems but the Windows version crashes with an error message that it doesn't find the stream.
Is streaming support broken in the Windows version?
Br,
Daniel
Ok, so I figure that I'm the only one having this problem?
Or should i treat the silence as no one using this function?
Are there anyone using web radio in XBMC for WIndows?
Confused
i just confirmed it crashes xbmc. the xbox could be using mplayer to connect to the mms stream.
fixed in svn.
Ooh, kisses to you Wiso! Big Grin
