2020-10-08, 18:25
(2020-10-08, 08:41)RockerC Wrote: [ -> ]Should maybe note that the upcoming upgrade to Android 11 for Android TV will contain a new Generic Kernel Image (GKI) which should bring additional device drivers.Can I use paragon for exFAT and NTFS drives connected through hub to play local content from a SSD through Kodi on the new "Chromecast"?
https://source.android.com/setup/start/a...ase#kernel
Android 11 release introduces Android Common Kernels (also known as the AOSP common kernels or ACKs) though which Android TV 11 kernel version release is unclear?
https://source.android.com/devices/archi...oid-common
Should hopefully have many more peripherals drivers for USB hub chips, wired network adapters, Wi-Fi adapters, storage controllers, and more.
(2020-10-07, 17:31)azg64 Wrote: [ -> ]Several USBC hubs work according to this Reddit thread:
https://www.reddit.com/r/Chromecast/comm...urce=share
Still not a cheap solution but at least there are few USB-C hubs that feature integrated 1Gbps Ethernet adapters for those wanting wired Gigabit network.
Works:
Utaxo 8-in-1 USB C Hub: https://www.amazon.com/dp/B07RWG8M15/ (Confirmed by 2 DPs that it works and supports Ethernet and storage - FAT32 is the only supported format by CCGTV)
Anker USB C Hub, PowerExpand 8-in-1 USB C : https://www.amazon.com/Anker-PowerExpand...B087QZVQJX
Partially works:
TOTU USB C Hub,9-In-1 Type C Hub (ethernet and peripherals only - no storage): https://www.amazon.com/gp/product/B07FX2...UTF8&psc=1
Don't Work:
Aukey 5-in-1 with Ethernet (latest version ethernet drivers not supported): https://www.amazon.com/gp/product/B089M7...UTF8&psc=1
Thinking of buyin that thing, because amazon fire tv stick gets bloated more and more. But I'm using Disney+, Prime and Netflix, so a single kodi device isn't the solution.
