Full Version: Open EPG On currently playing channel
I’m running Kodi Leia with a tvheadend server and I’m pretty happy with the setup using embuary skin.
I searched for an answer but couldnt find one.
The minor issue I have is when opening the tv guide it doesn’t automatically go to the currently playing channel, just the last selected channel.
My use case is for example...
playing channel 1
open guide and scroll to channel 5
close but dont select that channel so still playing channel 1
open guide, sleected channel is still 5 but would like it to be the playing channel 1
Does anyone know if its possible to configure this behaviour somehow?
Thanks and great job to all the developers!
Is this possible
If I understand you correctly the setting 'Preselect playing channel' should do just that.
Enable it in Settings>PVR&Live TV>General
(2020-10-05, 23:02)Atreyu Wrote: [ -> ]If I understand you correctly the setting 'Preselect playing channel' should do just that.
@Atreyu exactly that! Many thanks, sometimes there are just too many settings and you cant see the wood for the trees Big Grin
