Full Version: Move current music queue to different kodi box?
I have several kodi instances around the house. I will select a few hours worth of music on kodi box ‘A’ but then go downstairs and I want to continue listening to the queue on kodi box ‘B’.
I share a mariadb between the four boxes if that helps.
is this possible?
thanks.
It's possible with yatse.
But personally I solved this with using snapcast on all instances and a snapcast server on one of them, so I start music on the instance running the snapcast server (via yatse, kore or web interface) and am able to control (with snapcast app) which instance(s) should playback...
(2020-10-08, 08:04)Uatschitchun Wrote: [ -> ]It's possible with yatse.
Thank you; looks like I have some researching to do but cheers for pointing me in the right direction
