Full Version: "TV Shows" is disabled. How can I enable it ?
As in the title.. is it normal to be disabled ? Should I do something to enable it ?
Thank you !
Where? Home screen?
(2020-10-13, 11:06)Hitcher Wrote: [ -> ]Where? Home screen?
No, in the menu -> interface -> skin -> configure skin.
(2020-10-13, 11:15)sionut Wrote: [ -> ]No, in the menu -> interface -> skin -> configure skin.
That is not the proper location for enabling the TV Show section.
The TV shows option is auto-enabled when you have enabled a video source as a TV show source, and have scraped its contents into Kodi's video database.
(2020-10-13, 13:15)Klojum Wrote: [ -> ]
Ok, that explains it. Now it's fine, I imported a tv show and the category appeared.
Thank you !
Thread marked solved.
