Full Version: how to remove the "Return" button in "Movies"
I'm trying to configure Kodi for a senior person who might be lost with too many menus.
I have customized Estouchy to show only Movies and Weather. So far everything is fine.
However, if I click on the Movies button on the left a list of movies is shown, as expected  (showing movies sorted/filtered by Titles). Before the movies icons though there is a Return icon which, if pressed, takes you to all kinds of filters (by Genre, Years..). Is there any way to remove that button altogether ?
Thank you !
I've never used Estouchy, but you should be able to remove the "up level" buttons using setting 1.1... https://kodi.wiki/view/Settings/Media/General
(2020-10-13, 11:15)Karellen Wrote: [ -> ]I've never used Estouchy, but you should be able to remove the "up level" buttons using setting 1.1... https://kodi.wiki/view/Settings/Media/General
Thank you ! It was exactly what I needed !
Thread marked solved.
