Full Version: Kodi 18.8.0 - Kodi fails to obtain images while scraping movies
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14
Kodi version: 18.8.0
Android version: 8.0.0
Device: Sony Bravia TV (running Android TV OS)
I've been running Kodi on my Android TV for many years now.  Just yesterday, I started encountering an issue where when I update my library, Kodi no longer pulls poster, fanart, actor images, etc from tmdb anymore.  The scrape does actually find the movie and adds it to my library.  It just no longer populates the images for the movie.
I've gone as far as clearing the cache for Kodi, then clearing the data, and even uninstalling and re-installing Kodi itself.  None of these steps seemed to fix the issue.
I went through the logfile and found the following error multiple times:
2020-10-14 05:35:36.598 T:18170   ERROR: CCurlFile::Stat - Failed: Failure when receiving data from the peer(56) for http://image.tmdb.org/t/p/original/s6cgA...brjSBt.jpg
2020-10-14 05:35:37.425 T:18171   ERROR: CCurlFile::Stat - Failed: Failure when receiving data from the peer(56) for http://image.tmdb.org/t/p/original/sovBd...3UwfZF.jpg
2020-10-14 05:35:37.449 T:18180   ERROR: CCurlFile::Stat - Failed: Failure when receiving data from the peer(56) for http://image.tmdb.org/t/p/original/8vQYi...8NClqI.jpg
2020-10-14 05:35:37.659 T:18180   ERROR: CCurlFile::Stat - Failed: Failure when receiving data from the peer(56) for http://image.tmdb.org/t/p/original/bdEMd...qbzNVj.jpg
If I understand the log lines correctly, it seems that Kodi attempts to fetch a .jpg file (likely a poster, fanart, actor image, etc) from tmdb.org and fails to obtain it.
I've taken the link to one of the .jpg files and attempted to open the link in a browser on my Sony Bravia TV.  The link opens successfully in the browser on my TV.
As part of my troubleshooting, I have tried scraping the movie files with my VPN turned on, VPN turned off, and added an exception in my VPN so Kodi can bypass the VPN completely, all with the same results.
I also have Kodi running on an Android phone connected to the same Wi-Fi network.  Kodi on the phone does not experience the same issue.  On the phone, Kodi is able to scrape the movies and obtain all images just fine.  Also, I can access the internet using other functions requiring internet access from Kodi on the Sony Bravia TV.  For example, I can watch a movie trailer just fine.  So I don't believe this is a network connection issue.
I have uploaded a copy of the logfile using the Kodi Logfile Uploader.  Here is a link to the logfile:
https://paste.kodi.tv/ewozowilub
This one is a bit of a headscratcher for me.  So any assistance would be greatly appreciated.
I'm having the same issue as per this morning, my log looks the same. Bunch of "ERROR: CCurlFile::Stat - Failed: Failure when receiving data from the peer(56)" lines with various image URLs. I can open the URLs normally in a browser.
Also having the same issue
@SBL_ , @OzPlanet
Full debug log (wiki), please.
Saying "metoo" does not really help.
(2020-10-14, 18:09)Klojum Wrote: [ -> ]@SBL_ , @OzPlanet
HI, I'm new to kodi and I'm having exactly the same issues.
MacOS version: Catalina 10.15.7
Device: MacBook Pro
Debug log link:
https://paste.kodi.tv/nemenudawi
Save for me.
I just got an Android box "X97 Max +", and when scanning/scraping nothing shows up. I have configured the movie folder and scraper setting, but not images at all.
Text info if fetched just fine, but no images
Thought I was going mad....
having the same issue.
Yep - have the same problem since this morning (GMT+1)
I have the same problem since today.
i get for example logs like this:
60   ERROR: CCurlFile::Stat - Failed: Failure when receiving data from the peer(56) for http://image.tmdb.org/t/p/original/rN3By...5U81fU.jpg
I have scraped 9 movies and had no problems with artwork with any of them.
If you are still having problems, provide the names of the the movies you are scraping.
I imagine the problem at TheMovieDB is temporary for your location and should fix itself. Are you all from the same general area?
Yeah, same here. Did they push a new version update yesterday? I wiped Kodi clean and did a fresh install today from Google play store but same problem exists. I didn't notice if it was a newer version than what I had.
(2020-10-14, 20:52)Karellen Wrote: [ -> ]I have scraped 9 movies and had no problems with artwork with any of them.
Well, I am in Denmark.
Don't know about the others who have reported the same.
(2020-10-14, 20:59)NormanC Wrote: [ -> ]
California here.
(2020-10-14, 20:52)Karellen Wrote: [ -> ]If you are still having problems, provide the names of the the movies you are scraping.
From Northern Europe. Changing artwork is impossible for everything in the library. It shows a number of options remote1, remote2 etc. but no actual "image preview" and the artwork is not added as usual on selection.
The failed image urls are working when accessing from a desktop browser and when using the "kodi web interface" all available images shows up and are added as thumbnails.
