Full Version: Sort options V4
Am I correct that the filter button/menu is missing the sort options? Sometimes used that to change my sort option to "date added".
It's possible with the new "select visible column", enable the column and the click it.  Just like to know if that's the correct way to do it now.
yes - in v3 we had 2 different way to sort which were not _compatible_. In v4 this is unified by just adding the ability to filter by the table headers - but also multiple column sorting and storing the sort order has been added
yes this is the right way to do it
