Full Version: Atmos for headphones in xbox kodi?
Hi, i'm trying to make atmos for headphones work in the xbox with kodi but it doesn't seem to work. Is there any setting to change?
thanks
(2020-10-15, 20:49)albur Wrote: [ -> ]Hi, i'm trying to make atmos for headphones work in the xbox with kodi but it doesn't seem to work. Is there any setting to change?
thanks
I was wondering the same , may be because kodi uses ffmpeg while you need to use system default audio api for atmos to run ,
i am not sure if it can still be done using ffmpeg though but this is the only reason i still use VLC although kodi is much better in everything else.
