Full Version: Pre-Release 4.0.5
Version 4.0.5
+ added support for trailer download to /trailers #787
+ re-added tinyMediaManagerCMD.exe for Windows command line execution
+ added subtitle count filter for TV shows
+ updated libmediainfo to 20.09
x completely reworked trailer downloading to fix several issues #1060
x reworked aspect ratio calculation
x lowered memory consumption of the imdb rating fetching
x draw table/tree grid when multiple rows are selected
x improved loading time of large libraries
x more precise search results when searching for text only
x added an option to specify which actors should be fetched from IMDB #1062
x updated live calculation of movie set/movie count #1064
x inversion of media file filter for TV shows #1063
x prevent trailer from being renamed from within /trailer(s) folder
x support reading of the mediainfo.xml for unsupported files (.disc, .img, ...)
x fixed reading of mediainfo via UNC paths #1071
x fixed some updater issues
x fixed macOS dock pin issue
x MPAA tag in the NFO now also respects the certification style setting
a new build is up:
Version 4.0.5
x fixed reading hybrid DVD ISOs
