[*]The above paths are based on Windows. For all other platforms see
Userdata (wiki) for the correct path.
[*]The language code needs to be 4 characters. If your selected language is still 2 characters, this change will not work for you. Please report it in this thread.
[/list]
** After user feedback this post has been updated with new instructions
[/quote]
Hopefully this have a similar solution, my log is filled with:
2021-01-03 14:01:36.802 T:2882610032 WARNING: CAddonSettings[metadata.universal]: failed to load value "en" for setting tmdbplotlanguage
2021-01-03 14:01:36.802 T:2882610032 WARNING: CAddonSettings[metadata.universal]: failed to load value "en" for setting tmdbsearchlanguage
2021-01-03 14:01:36.802 T:2882610032 WARNING: CAddonSettings[metadata.universal]: failed to load value "en" for setting tmdbsetlanguage
2021-01-03 14:01:36.802 T:2882610032 WARNING: CAddonSettings[metadata.universal]: failed to load value "en" for setting tmdbtaglinelanguage
2021-01-03 14:01:36.802 T:2882610032 WARNING: CAddonSettings[metadata.universal]: failed to load value "en" for setting tmdbtitlelanguage
2021-01-03 14:01:36.802 T:2882610032 WARNING: CAddonSettings[metadata.universal]: failed to load value "en" for setting tmdbtrailerlanguage
2021-01-03 14:01:36.809 T:2882610032 WARNING: CSettingsManager: unable to read value of setting "tmdbgenreslanguage"
2021-01-03 14:01:36.809 T:2882610032 WARNING: CSettingsManager: unable to read value of setting "tmdbplotlanguage"
2021-01-03 14:01:36.809 T:2882610032 WARNING: CSettingsManager: unable to read value of setting "tmdbsearchlanguage"
2021-01-03 14:01:36.809 T:2882610032 WARNING: CSettingsManager: unable to read value of setting "tmdbsetlanguage"
2021-01-03 14:01:36.809 T:2882610032 WARNING: CSettingsManager: unable to read value of setting "tmdbtaglinelanguage"
up to the point that I can't upload any logs (probably due to the size because of the above messages).
I'm on RPi. My TMDB for Movies version is 5.2.6 and my TMDB tv show version is 3.5.12. Both of them only have 2 letters for language code like you mentioned. What can I do to fix this?
