(2020-10-25, 10:47)cucol Wrote: [ -> ] (2020-10-21, 16:20)smee204 Wrote: [ -> ]I am looking at replacing an aging 10yr old Intel PC which is currently running dual boot libreElec for Kodi and Windows 10 for very light Steam gaming.
Kodi is mostly used for playing recorded 1080p TV from mythtv as well as some DVD/bluray rips.
I need something small and have been looking at two options so far:
- Intel NUC10i3FNH (i3-10110U)
- ASUS PN50 (AMD Ryzen 3 4300U)
Both are overkill in terms of performance but hopefully they will last me another 10 years.
Which would be best for playback and support, Intel or AMD? The AMD is more powerful but I wasn't sure if the support is as good.
Are there any other recommended mini PCs that would handle light gaming?
I'm in the same situation, tired of Intel nuc not supporting native hdmi 2.x and really interested in this pn50 nucs.
I want to know if hdmi cec is working on windows and how is working.
Is the nuc going to power on when i power on the tv? Or only when i switch to the assigned hdmi input?
When i switch back from this input back to another hdmi or tv, what's going to happen? Power of? Stand by?
Thank you.
I just got one to test hdmi cec on the asus pn50,
fresh windows 10 late 2020
amd chipset drivers and gpu adrenaline drivers
kodi
HDMi 2.1 cable to a LG C7V 65
Latest bios as of today, there are a few cec bios settins, you can control what u want to do when TV shuts down (stanby os button, power off button, nothing) for wakeup when tv turns on (disabled, froms s3, s4, s5)
Hibernate/stanby button is working fine when you power off/on the TV
When you power on the TV if the pn50 is shutdown (s5) will not come back, but works fine on wake up from hibernate
So hdmi cec is working "fine" btween my lg and pn50 on wu/shutdown.
But not working at all controlling the kodi/windows 10
i checked the settings / input / on kodi but there is nohing there, just empty and no hdmicec
im not sure if there is something missing, but may be just my old LG not doing good cec. Just the power command is working at windows, shutting down windows fine. maybe asus just implemented the power on/of part of cec, idk. Just dont work on my pn50/lg c7v
Anyway the when i press the lg direction pad on the remote, the tv just go for the "tv" settings, not even tries to "send" cec commands. Idk, maybe someone can help me to test something to know if this is a TV or PN50 limitation.
LG got a magic controller funtion and you can set the hdmi1 to a Microsoft Box, and this works on windows 10 and kodi, but is iR emulation, and you lose the power on/off part of hdmi cec (ir emulation seems to disable cec completely)
So i cant throw my armony remote and just use the LG remote for everything, ir emulation cant handle power on/off the asus, but fine on kodi/windows directions and enter, and cant use CEC because just works on hibertante/wu, but wont on controlling windwos/kodi.
