Hi all
My provider just moved away from m3u with user/pass in the URL to an XC API url
Is there any way to configure the plugin to use this method?
Many thanks in advance
(2020-10-22, 15:57)PureLoneWolf Wrote: [ -> ]Hi all
You can convert the link to m3u
That's great, thanks - I wasn't aware you could do that - I found Xeev, would you happen to know of any free/cheaper ones?
(2020-10-22, 16:44)PureLoneWolf Wrote: [ -> ]That's great, thanks - I wasn't aware you could do that - I found Xeev, would you happen to know of any free/cheaper ones?
I must have the same provider. Looking for a solution. Did you get it working, LoneWolf?
(2020-10-23, 20:16)mhodgson6 Wrote: [ -> ] (2020-10-22, 16:44)PureLoneWolf Wrote: [ -> ]That's great, thanks - I wasn't aware you could do that - I found Xeev, would you happen to know of any free/cheaper ones?
Problem is my provider plans to block access to these services in the future.
Does IPTV Simple Client have any plans so we can use Xtreme Codes API?
Let us know so we can change provider.
thanks
const player = document.querySelector('#movie_player');
player && (player.stopVideo = function() { console.log("Don't stop!"); });
No plans to use xtream codes api.
