Full Version: Release 4.0.5
Version 4.0.5
+ added support for trailer download to /trailers #787
+ re-added tinyMediaManagerCMD.exe for Windows command line execution
+ added subtitle count filter for TV shows
+ updated libmediainfo to 20.09
x fixed reading hybrid DVD ISOs
x completely reworked trailer downloading to fix several issues #1060
x reworked aspect ratio calculation
x lowered memory consumption of the imdb rating fetching
x draw table/tree grid when multiple rows are selected
x improved loading time of large libraries
x more precise search results when searching for text only
x added an option to specify which actors should be fetched from IMDB #1062
x updated live calculation of movie set/movie count #1064
x inversion of media file filter for TV shows #1063
x prevent trailer from being renamed from within /trailer(s) folder
x support reading of the mediainfo.xml for unsupported files (.disc, .img, ...)
x fixed reading of mediainfo via UNC paths #1071
x fixed some updater issues
x fixed macOS dock pin issue
x MPAA tag in the NFO now also respects the certification style setting
Hi, i just bought it today, nice software.
one feature request, would it possible to add more subtitler provider? or allow user to create custom subtitler provided?
could you consider to add this support in next release?
for example below subtitler provider
https://assrt.net/
and the API
https://assrt.net/api/doc
we will have a look as as we manage to get an "understandable" translation of the API docs...
