Here is a clear and concise description of what the problem is:
I have been using kodi for nearly a month now.However,Whenever I scan my library for new content,the
scrapers don't work and the whole window freezes.I use Task Manager To Close Kodi.
Here is the Debug log:
Debug log
I Also Tried THE Following things:
1) Overwrite the Installation
2)Reinstalled it.
3)Ran it as Administrator but to no avail.
I am using Windows 7 and Kodi v18.9.I have raised the issue on Github as well.
Please Help me.Here are some Screenshots.
(2020-10-29, 09:11)Karellen Wrote: [ -> ]@DarkKnight939
You may have uploaded the wrong log as there is nothing to see in the one you provided. Be aware of the difference between kodi.log and kodi.old.log... https://kodi.wiki/view/Log_file#kodi.log...di.old.log
When you create the log again, ensure you run the scraping process and capture the crash.
I Ran the Crash Again,this time it was for nearly a minute and a half
Here is the second log file:
Log File2
Is The File Correct
(2020-10-29, 12:46)DarkKnight939 Wrote: [ -> ] (2020-10-29, 09:11)Karellen Wrote: [ -> ]@DarkKnight939
Log File2
Is The File Correct
2020-10-29 16:11:49.106 T:5840 ERROR: AddOnLog: Joystick Support: Failed to load XInput DLL
2020-10-29 16:11:49.106 T:5840 ERROR: AddOnLog: Joystick Support: Failed to initialize interface xinput
I found THE ERROR,is it Correct?Do i need to reinstall XInput DLL ??
(2020-10-29, 12:46)DarkKnight939 Wrote: [ -> ] Is The File Correct
Unfortunately not. You uploaded the wrong log again.
Forget about using the log uploader as this is what is confusing you, and you don't need it anyway.
Your log is located here...
C:\Users\USER\AppData\Roaming\Kodi\
Run your scraping again and ensure Kodi crashes
Once this happens
do not restart Kodi
Go to the above folder, find
kodi.log open it and copy the contents to
Kodi Paste Site
Save it and provide the link.
If not sure how to use
Kodi Paste Site, see here...
https://forum.kodi.tv/showthread.php?tid...pid2839494
(2020-10-29, 18:33)Karellen Wrote: [ -> ] (2020-10-29, 12:46)DarkKnight939 Wrote: [ -> ] Is The File Correct
Your log is located here... C:\Users\USER\AppData\Roaming\Kodi\
Once this happens do not restart Kodi
Go to the above folder, find kodi.log open it and copy the contents to Kodi Paste Site
If not sure how to use Kodi Paste Site, see here... https://forum.kodi.tv/showthread.php?tid...pid2839494
The error hs been resolved.I had some zip files in the directory,when i deleted them and rescaned it it works properly.However,I have another error when i try to edit movie posters with custom thumbails,the window freezes,but meh i might as wait for v19 "Matrix",it may get resolved then
