2020-10-30, 20:21
As said in the subject the audio is missing from some channels. I have AC-3 working in some channels and not others same with AAC. What may be the cause of this.
(2020-10-30, 20:21)pelle74 Wrote: [ -> ]As said in the subject the audio is missing from some channels. I have AC-3 working in some channels and not others same with AAC. What may be the cause of this.I sometimes see this happening as well. It seems to my affect HD channels more than regular SD.
(2020-10-30, 22:07)Dumyat Wrote: [ -> ]I was going to get som loggs to post when it suddenly worked! Probably bad streams. Thx for your effort.(2020-10-30, 20:21)pelle74 Wrote: [ -> ]As said in the subject the audio is missing from some channels. I have AC-3 working in some channels and not others same with AAC. What may be the cause of this.I sometimes see this happening as well. It seems to my affect HD channels more than regular SD.
What happens if you leave the channel playing for maybe 30 seconds? Still no audio?
Normally the audio on my affected channels eventually kick in after about 30 secs approx.
Like you, at first I thought I was getting no audio at all, but then sussed if I waited a few seconds the audio would catch up with the video stream.
EDIT: Missed you were using the IPTV client. If the above does not work for you, then maybe the problem is caused by unreliable stream, but posting a log will certainly help to identify the issue.
