Full Version: Touchscreen skin with bigger player buttons?
Hi!
Some quick background: Got a new treadmill, and since just running is Very Boring™ I mounted a Raspberry Pi with a 7" screen on it. Yeah, not a big screen, but anyway…
I installed OSMC on it and picked the Estouchy skin (the default wasn’t very handy with a touch screen). In the menus, it works perfectly, but in the video player the buttons are rather small, to the point where they’re essentially unusable on the run (or even when not running).
1) Is there a way to change the size of the buttons in the video player, either through a setting or through modifying an XML?
2) Is there a different touchscreen skin that I could try?
the easiest way would be to increase the spacing between those buttons.
you can modify this line in IncludesPlayerControls.xml:
https://github.com/xbmc/xbmc/blob/master...s.xml#L300
try is setting the value to 70 works better for you.
(2020-11-01, 23:32)Toll Wrote: [ -> ]Hi!
I have created a custom skin that I think is "good enough" for a Raspberry Pi 7" touchscreen.
It's not really ready for sharing with the community, but it you wanna give it a shot you can get a snapshot at https://1drv.ms/u/s!AjBPRo9wXw9s8N1bQELo...A?e=iLdTHn
(The name comes from the fact the Pi+Kodi replaces an old Noxon device from Terratec  Wink )
